May 05, 2024, 02:18:06 AM *
Pages: [1] 2 3   Go Down
Author Topic: AM Transmitter Rally - 2015  (Read 31645 times)
« on: December 21, 2014, 01:10:17 PM »
Thanks to the efforts of Brad - K4RT, we are happy to announce
The AM Transmitter Rally, 2015, 21-23 February 2015.
Please see the link below for the details.
AMTR 2015
Place questions and discussion in this thread.
Hope to hear all of you on the air!
N8SDR
« Reply #1 on: December 21, 2014, 06:06:03 PM »
When viewing the hyperlinks regarding the logging information and available files posted in the http://amfone.net/AMTR/AMTR-2015.html  I noticed an error in the 3 hyperlinks regarding the logbook information and files available:
Within the hyperlinks there is an error they point to
http://amfone.net/AMTR/www.classeradio.com/amtrlog.htm
http://amfone.net/AMTR/www.classeradio.com/amtrlog.xls
and
http://amfone.net/AMTR/www.classeradio.com/amtrlog.csv
The links to these files if your using the hyperlinks need to have the:  http://amfone.net/AMTR/   Removed from them
the correct links are
and
N8SDR
« Reply #2 on: December 21, 2014, 09:13:14 PM »
Nice catch. I didn't test those links. They have been corrected.
Thanks.
ka4koe
It's alive. IT'S ALIVE!!!
« Reply #3 on: December 22, 2014, 08:19:07 PM »
Jeff K1NSS made up a nice banner for the event. Its listed on an earlier discussion.
PAN
« Reply #4 on: December 23, 2014, 12:11:44 AM »
not to be a pest but on http://amfone.net/AMTR/AMTR-2015.html there is shown a picture of the log, but the cat column is shown  as the same as the time column. It is confusing. Could this please be clarified/fixed? Thank you for taking care of this event!
« Reply #5 on: December 23, 2014, 02:17:33 AM »
It appears to me that if you're going to operate CAT C, you could enter the time contact as 2143C, next one as 2148C, etc. If later in the rally, you change categories, say now Category (CAT) E, your time contacts would be 0232E, or 0314E, etc.
« Reply #6 on: December 23, 2014, 01:04:07 PM »
Don't worry too much about the CAT: entry  Smiley  Almost everyone uses the logging software anyway, and the software puts the CAT: entry into the database automatically and you never have to worry about it.
If you send in an entry by some other means (paper logs, execl, etc), just specify the station category based on the transmitting equipment you're using.
We make it work one way or the other!
Regards,  Steve
K4RT
« Reply #7 on: December 23, 2014, 05:10:04 PM »
How about adding a "Cat" column to the log form as shown in the attached image?  Steve, could the logging software be updated to add a CAT column?  If so a "Cat" column could be added to the Excel version of the log.  I can create a PDF paper log form for those who just want to print a log form and hand-write the log entries.
ka4koe
« Reply #8 on: December 23, 2014, 07:19:13 PM »
I've forwarded the time/date correction info to Jeff. We'll post an updated file when he is finished with it.
Philip KA4KOE
K1NSS
OM Cartoonist
« Reply #9 on: December 23, 2014, 08:15:14 PM »
Sorry gang, will correct.  Thanks for the heads up Philip and kudos K4RT. I thought it was the 500 but I'm probably not hip to the finer points. Like, maybe there's no such thing as a 500, HI! Good old WRL.
We have met the enemy and he is THEM.
« Reply #10 on: December 24, 2014, 12:15:16 PM »
I think for this year, it would not be a good idea to make any database changes.
So far since the event started (I don't remember how many years it's been - would 2015 be the 5th year?) station categories have been non-problematic.
But, we can definitely discuss for future events for sure!!!
Hopefully we will have low static and good propagation for the 2015 event.  That makes SUCH a difference!
« Reply #11 on: December 24, 2014, 01:09:21 PM »
Yep. You're either going to get on the air or you're aren't. A logging program should not be the focus.
« Reply #12 on: December 25, 2014, 08:30:18 PM »
The category is only used by the data reduction software (and is part of the data reduction output), and is otherwise not used, so it's pretty minor :-)
K4RT
« Reply #13 on: January 05, 2015, 11:14:53 PM »
If you plan to participate in the 2015 AM Transmitter Rally Feb. 21-23 but will not be using logging software, you might find the attached (to this post) summary sheet and log sheet useful.
The 2-letter Canadian province codes can be found here: http://www.comeexplorecanada.com/abbreviations.php and 2-letter international codes here  http://patft.uspto.gov/netahtml/PTO/help/helpctry.htm
* AMTR-LogSheet.pdf (60.53 KB - downloaded 154 times.)
* AMTR-SummaryForm.pdf (86.22 KB - downloaded 172 times.)
« Reply #14 on: January 18, 2015, 07:34:56 PM »
Summary Form and Log Sheet for the AMTR are also available at the link below.
www.qsl.net/k4rt/amtr/forms.htm
« Reply #15 on: January 18, 2015, 08:42:53 PM »
As of today, there are only 2 special event call signs issued. I'm sure that they'll get some radio leg fer sure.
          STRAP!
K4RT
« Reply #16 on: January 18, 2015, 11:16:30 PM »
Thanks Kevin.
Special event calls reserved for the 2015 AMTR:
K4K   (by WA4JK)
K5T   (by KX5JT)
W1E   (by WA1QIX)
W1G  (by KB2WIG)
W9T   (by W9GT)
Updated 01/23/2015
KX5JT
John-O-Phonic
« Reply #17 on: January 18, 2015, 11:41:42 PM »
Which service is best to apply for special event call?  Is there a fee?  Should I do this?
AMI#1684
K4RT
« Reply #18 on: January 19, 2015, 11:29:54 AM »
John - I have reserved 1x1 call signs in the past through the web site http://www.1x1callsigns.org/index.php/search but there may be others.  It's been a couple of years since the last time I reserved a 1x1, but I never had to pay a fee.  It's best to reserve a 1x1 early.
If you use a 1x1 call sign, there's the possibility that you will receive requests for hard copy QSL cards, so you should have a means to print QSL cards in case you receive any requests.  If that's not a problem or concern, then I would say go for it.
Brad
« Reply #19 on: January 19, 2015, 12:06:22 PM »
B,
The Official card.
« Reply #20 on: January 19, 2015, 07:20:20 PM »
U __ ain't right __
« Reply #21 on: January 19, 2015, 10:03:54 PM »
What a great suggestion! This event may be a good chance to unload some of the extra QSL cards lying about.
K4RT
« Reply #22 on: January 20, 2015, 12:32:12 AM »
KLC, Nice work!
I can't top that, but I made a quick & dirty rally QSL using an old QSL card as a template using MS Paint (attached).  If anyone is interested in using something like this to print their own rally cards you probably have the tools on your PC to do it without too much work.  If not, I can clean up the attached image and put your 1x1 and name and QTH on there and send it to you as a JPG or GIF.  You'll have to figure out the size for best resolution on your printer and let me know.
If memory serves, I think I read some years ago about a ham who prints his own QSLs on card-stock he buys at an office supplies store, thin enough to feed into a home printer, printing several cards on each sheet then separating them with a paper cutter or scissors.  The info might be on the web.
W9GT
« Reply #23 on: January 20, 2015, 09:33:35 AM »
I plan to be using W9T again this year.  Hope to see you all during the Rally!  Smiley
73,  Jack, W9GT
73, Jack, W9GT
« Reply #24 on: January 20, 2015, 08:31:11 PM »
KLC, Nice work!
That's exactly what I do except I don't have a color laser printer. There isn't much to it. I create the card in paint to use an image/photo and then add text still using paint, then save and paste into word so there are several on a page. I take the file to a full service office supply store, and print a proof. If all is well, I buy a pack of matte card stock and have it laser printed. Then use their paper cutter in the self serve area to chop them up. Note the new paint program in w7 and up is not too good for this, has to be the older 2000/XP version or it messes up the letters and even pixels with some kind of 'clear type' idiocy. The real card has much greater detail than this pic. The thing is that they are expensive to make because of the color laser print, copying fees, and the rest >$1 each.
Pages: [1] 2 3   Go Up
