April 27, 2024, 07:55:56 PM *
Author Topic: VLF Power Meter  (Read 2933 times)
wb1aij
« on: January 05, 2007, 05:21:15 PM »
Does anyone here know of any R.F. power meters that will read forward & reflected power or have schematics for one?
« Reply #1 on: January 05, 2007, 09:18:30 PM »
What operating Z?
If 50 ohms it should be easy. Just use higher Ui core material for the current transformer.
I would think type 77 or 73 or maybe even higher for 137 KHz.
I used type 61 (Ui=125) in my HF watt meter.
wb1aij
« Reply #2 on: January 07, 2007, 06:38:30 PM »
What operating Z?
Thanks for the info... The Z is going to be 50 ohms & the frequency will be 150-200 khz. This is an industrial application and will not be transmitted into the "ether" The xformer sounds like a good place to build around on a breadboard rather than modifying an existing unit for H.F.
« Reply #3 on: January 07, 2007, 08:33:53 PM »
Bob,
I just sent you a PM check it out. I think I can help.
« Reply #4 on: January 10, 2007, 08:43:59 AM »
AM Forum a good way to connect hams working on the same project
