August 08, 2026, 02:57:59 PM *
Pages: 1 2 [3] 4 5   Go Down
Author Topic: Avatars  (Read 256952 times)
Roy K8VWX
Pr. 4 -1000s Mod Pr. 5868
« Reply #50 on: September 03, 2006, 04:06:37 PM »
The size I was trying to post is 324x243 pixels and I do not get an error?
« Reply #51 on: September 03, 2006, 07:34:02 PM »
You won't get an error message. It just won't load the avatar. The one you want to post is too big. 100 X 175 is the max.
Roy K8VWX
« Reply #52 on: September 03, 2006, 07:45:11 PM »
Just shrunk my picture t0 133X100 and it still will mot post - I GIVE UP
N3AMX
Formerly N3WWL
« Reply #53 on: September 03, 2006, 07:47:07 PM »
133 X 100 WONT WORK
TRY 100 X 133
Syracuse Radio W2INR
« Reply #54 on: September 03, 2006, 08:35:50 PM »
No more than 100 wide and 133 high Roy
Gary
SWLR-RNØ54
Roy K8VWX
« Reply #55 on: September 04, 2006, 07:14:13 AM »
WOW! I got it to work - Thanks Gary and all who helped . (100 wide X 133 high fit) Smiley
« Reply #56 on: September 04, 2006, 07:35:35 AM »
Nice PIC. Roy
SWLR-RNØ54
Carl WA1KPD
« Reply #57 on: September 28, 2006, 12:36:12 AM »
Gary
92 x 95 and I point it to my c drive and the pic file (jpg), press change profile and nothing happens to my profile.
Any ideas?
Tnx
KPD
« Reply #58 on: September 28, 2006, 01:26:17 AM »
Carl:
If it's the same picture you have in your post, I measure it as 130 W X 145 H. You have to size it down, save it, and then bring the saved picture into the profile.
Carl WA1KPD
« Reply #59 on: September 28, 2006, 02:08:37 AM »
Hi Pete,
It is a smaller version  (92x95) of the same pic
Tnx
« Reply #60 on: September 28, 2006, 02:26:23 AM »
can you post the smaller one here as you did the larger one?
« Reply #61 on: September 28, 2006, 02:40:23 AM »
Hi Pete,
Tnx
I eyeballed your original picture with my graphics program down to 92X102, and as you can see, if you were here,  it uploaded fine.
Carl WA1KPD
« Reply #62 on: September 28, 2006, 03:04:23 AM »
So I can see
Thanks Pete. I'll play with it some more tomorrow
KPD/0
« Reply #63 on: September 28, 2006, 01:41:38 PM »
So I can see
KPD/0
Brain doesn't function that early in the morning. I should have attached the picture I did. Take the picture below, copied it to your hard drive directory; then go to your profile as before and upload the picture; click change profile; refresh screen and see if it appears both in the profile picture area and on the left side of the screen under "Personal Menu".
Carl WA1KPD
« Reply #64 on: September 28, 2006, 04:24:11 PM »
Houston, We have lift-off
Thanks Pete!
Rick K5IAR
« Reply #65 on: November 29, 2007, 09:47:17 PM »
Where do I find animated avatars or must they be constructed?  Is special software needed, if so, what?  Yes, I am a dummy about such things.  Grin
Thanks,
Rick/K5IAR
Rick K5IAR
« Reply #66 on: November 29, 2007, 10:08:25 PM »
Thanks Mack, I'll give it a shot.  What if I want to customize it?  Maybe the info will be with the avatar.
Rick
« Reply #67 on: November 29, 2007, 10:13:41 PM »
Remember, there's a limit to avatar size.
Something like this won't work:
Or this:
Rick K5IAR
« Reply #68 on: November 29, 2007, 10:24:02 PM »
Thanks Pete.  How do you do that?  Is it possible to animate any avatar or does it have to originate as an animation?  I would like a small animated avatar, but I haven't seen anything like I want.
« Reply #69 on: November 29, 2007, 11:24:16 PM »
The animations are just animated GIFs. As long as they meet the size requirements for avatars on this site, they will work just like any other GIF. I've used this one in the past. Created the animation myself.
« Reply #70 on: November 30, 2007, 12:38:03 AM »
If you're running Microsoft Windows, click start, then All Programs, and look to see if you have a program called Microsoft Image Composer. If you do, highlight it (run the mouse pointer over it) and see if you have a sub program called Microsoft GIF Animator. This program can gather a bunch of GIF frames and set them in motion. There are also some commercial animation programs on the market that allows you to do some real nifty things.
Here's a simple animation of 7 frames with 7 different pictures using GIF Animator. Pictures were grabbed out of my directory. As an example, you could take a bunch of pictures of a piece of equipment as you walk around it or as you rotate the equipment. You would use the Image Composer to scale them down and then add each one as a frame to the GIF Animator. The Animator also allows you to speed up or slow down the showing of each frame. When you're finished setting up all the frames, speed, etc., you can save it as a GIF file.
Rick K5IAR
« Reply #71 on: November 30, 2007, 10:12:30 AM »
Pete,
Thanks a million!  I'll check to see if I have the MS program as I do run Windows.  If not, I'll see about a commercially available package.  So, it's kind of like the old "flip books" we used to get in cereal and stuff?  Too cool.
Thanks again,
Rick
K9ACT
« Reply #72 on: November 30, 2007, 11:24:33 PM »
Just what pray tell is the point of an avatar?
I can understand a thumbnail pic of the ham or his shack or Teddy Bear for that matter.  Perhaps I am just too old to understand why grown men need to identify with silly cartoons.
As a point of interest, I have the same  opinion of those silly faces.
js
Rick K5IAR
« Reply #73 on: November 30, 2007, 11:34:33 PM »
Come on, Jack, lighten up.  I'm an old man and I still like Ed, Edd and Eddy every now and then.  There is no purpose to avatars, they're just fun to some of us.   Grin
Rick/K5IAR
« Reply #74 on: November 30, 2007, 11:51:33 PM »
An avatar (abbreviations include AV, ava, avie, avy, avi, avvie, avis, avies, avii, and avvy) is an Internet user's representation of himself or herself, whether in the form of a three-dimensional model used in computer games,[1] a two-dimensional icon (picture) used on Internet forums and other communities,[2][3] or a text construct found on early systems such as MUDs. The term "avatar" can also refer to the personality connected with the screen name, or handle, of an Internet user.[4]
The ( silly faces ) are called emoticons.
Definition:An emoticon is a short sequence of keyboard letters and symbols, usually emulating a facial expression, that complements a text message. An abbreviation itself (of emotion icon), the term is sometimes referred to by the name of the original emoticon, the smiley.
 A portmanteau of emotion (or emote) and icon, an emoticon is a symbol or combination of symbols used to convey emotional content in written or message form. Some examples of text-based emoticons include:   Smiley   Sad
SWLR-RNØ54
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.166 seconds with 19 queries.
