March 18, 2026, 11:15:41 PM *
Author Topic: Flameotrol Tube  (Read 8974 times)
« on: June 30, 2016, 07:46:37 PM »
It is marked CK 5608.......I find 5608 without the ck prefix and it looks like a dual triode....link...( https://frank.pocnet.net/sheets/201/5/5608.pdf  )  1948 date Labeled for Wheelco corp.   Has a sticker that says DANGER..."When top of glass shows white, REPLACE TUBE"     Has 2 pins strapped together on the base...I will post some pictures...
« Reply #1 on: June 30, 2016, 07:54:47 PM »
Ok
Mike/W8BAC
« Reply #2 on: June 30, 2016, 08:04:30 PM »
Interesting Steve,
I hope you find someone here that knows what on earth this might be used in. I'll be monitoring, so to speak. Cool
Mike
« Reply #3 on: June 30, 2016, 08:07:37 PM »
5.5 watt dissapation per plate...med mu  audio uses?  Was originally used for burner control,fuel regulation ?
« Reply #4 on: June 30, 2016, 08:08:13 PM »
Used in flame control in boiler systems.
Honeywell,  if memory serves.
« Reply #5 on: June 30, 2016, 08:15:24 PM »
Cool boxes...
KA0HCP
« Reply #6 on: June 30, 2016, 08:48:40 PM »
The tricky part is slipping the match in to light the tube!
« Reply #7 on: June 30, 2016, 09:51:57 PM »
IF..... it is in fact a 5608.... it was designed for ac on the plates.....What would be the design difference between AC or DC plates?  Could the tube be used with DC on the plate...??
« Reply #8 on: June 30, 2016, 11:05:44 PM »
The 5608 is a simply a medium Mu, duo-triode with a common cathode (pin 4).
The  5608 was replaced by the 6J6:
https://frank.pocnet.net/sheets/093/6/6J6.pdf
One could use it as a dual medium mu audio triode. With the strap the filament will be at the same potential as the cathode.
I saw this once in a boiler control. it was the first AND gate so to speak.
One of the grids sensed pilot light heat via a thermocouple, the other grid went to an "on" or activate switch. Both plates went to the AC supply.
The cathode went to an AC relay that when pulled-in, opened the main burner gas valve.
« Reply #9 on: June 30, 2016, 11:07:18 PM »
From another manufacturer,  it is a 5608.
As referenced by this mfg being peddled on the Bay.
http://m.ebay.com/itm/5608A-DUAL-TRIODE-AMPLIFIER-TUBE-BARBER-COLMAN-31-011-300-CONTROL-/191888222442?nav=SEARCH
« Reply #10 on: July 01, 2016, 07:08:45 PM »
The 5608 was registered by Raytheon. Compare the curves and plate power roughly to a 6N7. or 6A6.
https://frank.pocnet.net/sheets/049/6/6N7.pdf
Mike/W8BAC
« Reply #11 on: July 01, 2016, 08:02:09 PM »
Good explanation Phil. That is an interesting use of a tube.
Mike
Page created in 0.028 seconds with 18 queries.
