May 15, 2024, 04:28:54 AM *
Author Topic: DISTRIBUTING AUDIO  (Read 2663 times)
KB5MD
« on: February 05, 2013, 12:46:06 PM »
I use several different transmitters at various times and switch the audio from the audio chain to each individual transmitter.  The big drawback
to doing this is that each transmitter has different audio drive requirements.  Is anyone using a distribution system of sorts to adjust the audio to each transmitter in advance rather than having to adjust each time  you change transmitters?  I am thinking of an audio feed with some type of attenuators for adjusting to each transmitter requirement.  Sort of a mixer in reverse. Any thoughts on this?
« Reply #1 on: February 05, 2013, 01:42:10 PM »
You need an audio DA (distribution amplifier) with individual output adjustments.
PM me and I'll get one to you.
MikeKE0ZUinkcmo
« Reply #2 on: February 06, 2013, 12:59:24 AM »
Why not use a Lo Z buffer/amp, with gain set to accommodate the rig needing the most drive and reduce the mic gain on the other rigs as needed.
Mike KE0ZU
KB5MD
« Reply #3 on: February 07, 2013, 06:07:12 PM »
All the transmitters are broadcast type with no mike gain on each one
nq5t
« Reply #4 on: February 08, 2013, 02:15:58 AM »
I use a Rane SM-26b for this purpose.  One input to six outputs with individual gain control.
There are several currently available on eBay (a couple at ridiculous prices), but $100 should get you one.
WZ5Q
« Reply #5 on: February 08, 2013, 04:30:29 AM »
Howdy Y'all,
I use a Behringer MX-882 Splitter/Mixer devoted just for this.
It's cheap and works like a hose for this application.
Mine is about 9 years old with no issues.
They have been selling for $90 to $110 bucks new on eBay.
http://www.behringer.com/EN/Products/MX882.aspx
Mike
WZ5Q
From Deep Down in the Dark Dismal Swamps of the Calcasieu
http://www.wz5q.net
Page created in 0.056 seconds with 18 queries.
