May 13, 2024, 10:31:16 PM *
Author Topic: Valiant clipper bypass produces distorted lows  (Read 1752 times)
radionut
« on: July 30, 2011, 09:05:21 AM »
I have bypassed the clipper circuit on my valiant but am not getting distorted or over driven lows. Any thoughts?  Here is how I did the bypass:
Removed the 6AL5 (V13) tube but left tube socket.  Remove C83.  Use a .1 uF and run it from Pin 6 of V12b to Pin 6 of V14 used a small shielded coax cable here.  Also on Pin 6 of V14: Snip or desoldered L45 lead and C94 from Pin 6 of V14.
On the first test the low was distorted so I changed the .1 uF out for a .05 uF it did not seem to help much.
Any thoughts are appreciated!
Ed/KB1HYS
« Reply #1 on: July 30, 2011, 02:10:57 PM »
Odd, I did that bypass more or less the same way. I forget the exact component values I used but they sound "close enough".
Of course, my audio is nothing to brag about Shocked
73 de Ed/KB1HYS
Page created in 0.031 seconds with 18 queries.
