March 11, 2026, 02:49:53 PM *
Author Topic: What is it? Stancor mod iron  (Read 5045 times)
KB0CIM
Gates BC1T
« on: May 12, 2011, 09:34:56 PM »
I dug up a Stancor transformer, someone labeled it "811 P-P 100W". Its small, About the size of a ART-13 mod transformer, just a little smaller. Same can style, terminals out the bottom. Primary has CT, no CT on sec. I can read some markings as follows... D.C. Res PRI 170 Ohms, D.C. Res. Sec 215 Ohms, Freq resp 200-5000, Test 3000 Volts, IR 1022. Also says T-102 PRI. Z-6000 SEC. Z-6000 Turns Ratio 1-1 Terminals are labeled 1-3 Pri (2 CT), 4-5 Sec. #6 N/C Any ideas what it really is? Another stamp may say "UADF-301089".
« Reply #1 on: May 12, 2011, 09:48:52 PM »
Maybe one of those TCS transformers. I think a pair of 1625 mod a single 1625.
KB0CIM
Gates BC1T
« Reply #2 on: May 12, 2011, 10:03:56 PM »
I should have looked more, found another one.. Collins PN# 677N201 20 Watts 6K to 6K 3KV test. Same pins as unknown stancor, looks the same with the Ohm meter too.
KB0CIM
Gates BC1T
« Reply #3 on: May 12, 2011, 10:19:04 PM »
Yep, TCS it is...
T-102 and TR-1022 as noted in the manual... And printed on the "unknown Stancor".
http://bama.edebris.com/manuals/military/tcs13/
« Reply #4 on: May 12, 2011, 11:39:04 PM »
I agree,  I have one, they are 20 watters.  They were made by Stancor, not sure who made the ones with the Collins label, probably Stancor made those too.
Welcome, you are now one of a exclusive group of proud TCS mod xfmr owners.
« Reply #5 on: May 18, 2011, 06:43:30 PM »
Yep, I have one and I used it back in the late 50's to modulate my AT-1 that I had on the CB band. I build an outboard power supply & modulator using two 6L6 tubes with 816 Mercury rectifiers. Of all the stuff that has come & gone over the years, I still have that home brew modulator.
I need to get it going again!!!
« Reply #6 on: May 18, 2011, 10:48:07 PM »
Wonder how many AT-1s were ever used on the Chicken Band.
One in original condition fetched big bux not too long ago on ePay.
« Reply #7 on: May 18, 2011, 11:37:59 PM »
with CH15 and 19 crystals or no?
KG6UTS
« Reply #8 on: May 19, 2011, 01:49:53 PM »
Quote from: KA2DZT
[/quote
I keep mine hidden in a TCS ~8^)
EdZ
