What voltage could I expect?
September 26, 2023, 11:03:48 AM *
Author Topic: What voltage could I expect?  (Read 5903 times)
4cx250
« on: March 17, 2011, 11:37:19 AM »
Hello All!
     I would like to permantly mount a meter between my chassis on the TX, and the 8 foot ground rod directly behind the TX.
     What could I see there?
Tnx,
« Reply #1 on: March 17, 2011, 11:40:55 AM »
Meter? Voltage? Current?
UL uses a current meter to measure leakage current in a similar manner. In some classes of equipment 20ma is a failure.
Depending on the ground path length between the 2 a few volts AC wouldn't be surprising, assuming the TX chassis is grounded somewhere else.
kg8lb
« Reply #2 on: March 18, 2011, 02:22:21 PM »
Wouldn't a direct , low impedance connection from the TX to ground rod prove more beneficial ?  Huh
4cx250
« Reply #3 on: March 22, 2011, 08:08:45 AM »
Hello All!
     I would still have a GOOD ground connection between the TX and the ground rod. Will I see any voltages?
     Will I see a good SNAP when I hook the TX chassis to the ground rod?
Tnx,
« Reply #4 on: March 22, 2011, 09:27:56 AM »
There's only one way to find out!!
I'd plug in the TX, turn it on and measure the voltage first. Ifn a cap failed in the TX there could be a goodly amount of voltage there.
In either event, if you're adventurous, unplug the TX, connect it to ground and plug it back in!!!
Take PIXS!! Grin
Page created in 0.093 seconds with 19 queries.
