What voltage could I expect?
January 27, 2021, 05:53:01 PM *
Author Topic: What voltage could I expect?  (Read 3838 times)
4cx250
« on: March 17, 2011, 11:37:19 AM »
Hello All!
     I would like to permantly mount a meter between my chassis on the TX, and the 8 foot ground rod directly behind the TX.
     What could I see there?
Tnx,
« Reply #1 on: March 17, 2011, 11:40:55 AM »
Meter? Voltage? Current?
UL uses a current meter to measure leakage current in a similar manner. In some classes of equipment 20ma is a failure.
Depending on the ground path length between the 2 a few volts AC wouldn't be surprising, assuming the TX chassis is grounded somewhere else.
kg8lb
« Reply #2 on: March 18, 2011, 02:22:21 PM »
Wouldn't a direct , low impedance connection from the TX to ground rod prove more beneficial ?  Huh
4cx250
« Reply #3 on: March 22, 2011, 08:08:45 AM »
Hello All!
     I would still have a GOOD ground connection between the TX and the ground rod. Will I see any voltages?
     Will I see a good SNAP when I hook the TX chassis to the ground rod?
Tnx,
« Reply #4 on: March 22, 2011, 09:27:56 AM »
There's only one way to find out!!
I'd plug in the TX, turn it on and measure the voltage first. Ifn a cap failed in the TX there could be a goodly amount of voltage there.
In either event, if you're adventurous, unplug the TX, connect it to ground and plug it back in!!!
Take PIXS!! Grin
