April 29, 2024, 11:09:06 AM *
Author Topic: My mobile KW (PS updated)  (Read 7184 times)
« on: December 28, 2010, 09:42:22 PM »
Regarding my subject "My mobile KW"
http://amfone.net/Amforum/index.php?topic=25004.0
Just reading a Heathkit ad from April 1966 QST.  The HP24 weighs out at 22 lbs.  Just checked my homebrewed PS - it weighs 30 lbs.  How 'bout that for some beef?
In a previous post someone suggested a power inverter.  Anyone have any thoughts on this ?
http://www.amazon.com/Power-when-Recreational-Traveling-Emergency-Electronics/dp/B0039H5BZA/ref=sr_1_fkmr0_2?ie=UTF8&qid=1293591131&sr=1-2-fkmr0
Al
PS: wish I knew how to to that nice url insert thingie
« Reply #1 on: December 28, 2010, 10:13:25 PM »
Wow that's cool but you will need to feed it 300 amps to get full power.
« Reply #2 on: December 28, 2010, 11:26:51 PM »
What? Insert a picture? Something else?
SM6OID
« Reply #3 on: December 29, 2010, 06:58:15 AM »
Hej!
My experience is that inverters like that generates a LOT OF RF JUNK.
Output voltage is usually a "modified square wave".
Some inverters that I've come across seems to have great difficulties to regulate the output voltage if the load is anything that is very different from resistive.
« Reply #4 on: December 29, 2010, 09:54:47 AM »
6 Leece-Nevilles all in a row in front of your 350 chevy....
« Reply #5 on: December 29, 2010, 10:35:54 AM »
Yea, but Al is an EMI guy.
« Reply #6 on: December 29, 2010, 11:09:06 AM »
A 100 watt light bulb in the trunk will help smooth the inverter output.
When I was "off the grid" I used a cheap truckstop inverter to run a motor that was pulse-width speed controlled..
It ran really rough and jumpy untill I turned on the light, then it smoothed out really well.
Pure sine wave inverters are getting cheaper all the time, and generate no more noise than a good switching PS ( that is after all what an inverter IS).
« Reply #7 on: December 29, 2010, 12:18:34 PM »
The newer inverters run at a high sample frequency so the magnetics get smaller.
A minimum resistive load makes any switcher happy.
« Reply #8 on: December 29, 2010, 10:16:38 PM »
Wish I could get more info on that beast. l wouldn't even consider an inverter that put out a SQ wave.  The web site won't offer a manual.
K5WLF
« Reply #9 on: December 29, 2010, 11:03:41 PM »
Al,
At that price and that advertised output, I'll GUARANTEE that it's a modified square wave (or as the marketing geeks call it modified sine wave). There's just no way any manufacturer could build a true sine machine and sell it for that.
Xantrex and Samlex are two manufacturers of good quality, true sine wave inverters.
http://www.xantrex.com
http://www.samlexamerica.com
ldb
K5WLF
K9PNP
« Reply #10 on: December 31, 2010, 12:37:34 PM »
This inverter uses a "modified sine wave", which is shown to be a square wave in the reference.  At least it is not a "pulse width modulated" sine wave;  I have had all kinds of interference problems with those, especially if not grounded exactly like the manual says.  Here is the manual for the 3000T.
* STP-3000_User_Manual.pdf (805.73 KB - downloaded 414 times.)
73,  Mitch
