July 27, 2026, 10:05:19 PM *
Pages: 1 ... 3 [4]   Go Down
Author Topic: Dont buy a flex radio...  (Read 54892 times)
« Reply #75 on: October 28, 2009, 02:42:44 PM »
What is the problem with the AMFONE web site? If I try to quote a long response, the window to type my reply along with the Quote jumps and I cannot get to the bottom of the quote to start typing...................Happens on every computer I use to access AMFONE. Three home computers and a work computer 33 mi. from home.
I was going to quote Rob about the display from SDR being a distraction. I find it pretty useful using my simple SoftRock Lite board that I can enable the proper filter or move the I.F. around to get away from an offending signal or broad signal or splatter from an A.M. QSO 4 kc away. And the listening pleasure resumes, instead of cursing and swearing.
The problem happens with IE.
« Reply #76 on: October 28, 2009, 02:56:35 PM »
Yep IE 7 or 8 or whatever I'm using now....
Not just AMfone, but every BB I frequent......
Wish I could find a setting somewhere, because it's VERY annoying!!   Huh
W2PHL
Phil
« Reply #77 on: October 28, 2009, 03:51:36 PM »
Need to read the specs:
Flex 3000 - For AM operation, the transmit audio response is from 10 Hz to 7.3 kHz, since it's controlled only by the firmware. http://kc.flex-radio.com/KnowledgebaseArticle50352.aspx
10 Hz to 7.3 KHz audio response would be nice, or is it 10Hz to 3.65 KHz audio response for a total AM TX bandwidth of 7.3 KHz? There seems to be some confusion out there.
I think therefore AM
« Reply #78 on: October 28, 2009, 04:02:48 PM »
Gee, I'm using Flex software with my HPSDR and the 10 band TX EQ goes out to about 8 KHz if I remember. My only issue is you can't modulate over 100% limited by software.
Flex IF is 10 or 11 kHz so that would limit the bandwidth
« Reply #79 on: October 28, 2009, 04:53:01 PM »
The specs in the links I provided should answer your question, but each sideband mode maximum is 3.65 kHz, so, since AM has two sidebands, 3.65 + 3.65 = 7.3 kHz.
« Reply #80 on: October 28, 2009, 05:56:37 PM »
yes Pete but previously you posted:
Flex 5000A or 5000C - For AM operation, the transmit audio response is from 10 Hz to 20 kHz, since it's controlled by the software. http://kc.flex-radio.com/KnowledgebaseArticle50044.aspx
Audo response and transmit bandwidth are two different things.
Rob
K6JEK
RF in the shack
« Reply #81 on: October 28, 2009, 06:21:58 PM »
Audio response and transmit bandwidth are two different things.
Rob
If the bandwidth is limited to 3.6K either side of carrier, no audio above that gets through, depending, of course on what we mean by limited.  In a dull (as opposed to sharp filter) that might mean some frequency like say 3.6K is the -6 dB point with a gradual roll off after that, so audio above 3.6K does get through, it's just progressively attenuated.  I suspect, however,  in the Flex it's a brick wall filter so zip above 3.6K gets through period.  The Tx equalization above that is irrelevant.  That audio is not getting out of the radio.
I have listened to a Flex 3000 and watched it on the panadpater of my Flex 1000 so I should know the answer but dang I forgot.
I am right about this, aren't I?
W2PHL
Phil
« Reply #82 on: October 28, 2009, 06:36:33 PM »
Yes that's correct. If the Flex 3000 transmits 10 Hz to 7.65 KHz worth of audio response, then it's AM signal would be 15.3 Khz wide.
Pages: 1 ... 3 [4]   Go Up
Page created in 0.038 seconds with 17 queries.
