January 14, 2026, 02:08:37 AM *
Author Topic: WANTED..DWG FER S/STATE 5U4s..  (Read 3482 times)
ve6pg
« on: August 11, 2007, 11:49:55 AM »
..hi from tim..cant seem to find my info, but i'm looking fer the skizmatic for various solid state replacements for 5u4/5v4/5y3... diodes, etc..pin-outs, etc...got some blown tubes, and want to solid state the low voltage on some stuff...sk..
« Reply #1 on: August 11, 2007, 01:19:09 PM »
Try here, it'll show how to ss a Junkston Valient
http://www.amwindow.org/tech/htm/valiant/ps.htm
then here fer the pin outs, specks
http://www.nj7p.org/Tube.php
mouser, etc have   1n4007s by the bagfull... they are cheep ,  1A 1KV,   just string em up... a busted tube makes a good plug, or get a plug at a fest, etc......   klc
« Reply #2 on: August 11, 2007, 03:17:54 PM »
Fyi, the added diodes in the PS schematic for the Valiant is to get a higher B+ for the modulator tubes - it's not a "stock" conversion to solid state rectifiers. Otoh, the diagrams on the bottom show what to do with Octal plugs to put diodes in the hole.
A case can be made to control the application of the B+ via a means of delay until the filaments are warmed up. A relay and switch or a relay and time delay circuit will suffice, although there are other ways to accomplish this.
« Reply #3 on: August 13, 2007, 09:51:25 PM »
I ripped out the glass and put a hunk of vector board in the hole. 5 1n4007s in series each leg. anode end to the plate so you need 2 strings. Cathode to cathode end of string. my V2 at full bore is getting 760 volts with 16 uf output cap. Make sure you have good spacing between strings. I used G10 vector board. The board sticks out of the tube base a couple inches. stock rectifiers had about 100 volts drop.
Ed-VA3ES
« Reply #4 on: August 13, 2007, 10:17:35 PM »
Tim, you're  better off with 1N5408 rectifiers. These are 3A 1000V PIV  diodes.   Easy to find.
