May 04, 2024, 03:44:12 PM *
Author Topic: Monitoring Transmit Audio?  (Read 6969 times)
Bow/KD5KZN
« on: March 16, 2007, 09:11:45 AM »
How do you guys monitor your TX audio?
Second receiver?
Your Transmitter is equipped with a circuit?
Secret decoder ring?
Crystal radio set?
I am just wondering, I have tried the second radio receiver method, but the receiver gets pretty overloaded, even with the transmitter on low power into a dummy-load.
Is the a good way to listen to the transmit audio, as it sounds after it leaves the radio?
kc2ifr
« Reply #1 on: March 16, 2007, 09:36:06 AM »
I use this little gem.......check it out.
http://www.radioassociates.com/
2ZE
« Reply #2 on: March 16, 2007, 09:39:34 AM »
or this.....
http://amfone.net/ECSound/Monitor.htm
Syracuse Radio W2INR
« Reply #3 on: March 16, 2007, 10:22:16 AM »
All I use is an old used broadcast off the air monitor and a scope.
 I can hear myself and see my peaks, the negative line and carrier shift. Thats all you really need.  A good diode monitor can provide a good off the air audio reference also coupled with a scope will do the same job just not as fancy but just as effective.
SWLR-RNŲ54
AB1GX
« Reply #4 on: March 16, 2007, 12:14:14 PM »
So I should attenuate the rf out and send it to a detector and on to my scope.  Then I can compare my microphone audio out on one trace with the transmitted audio on another trace and look for flat tops and bottoms, right.
Second, I should also send the detected output buffered into a pair of earphones to monitor sound quality.
« Reply #5 on: March 16, 2007, 03:28:30 PM »
I just use my receiver.
W2JBL
« Reply #6 on: March 16, 2007, 09:30:10 PM »
I use my receiver. if you do this it needs to be a receiver with a good stout front end, and your antenna relay has to have excellent isolation. Rf cabling has to be good- well sheilded and the receiver at least installed in it's cabinet. otherwise if the thing overloads (easy to do) you won't do very well.
« Reply #7 on: March 16, 2007, 10:06:12 PM »
I use a simple diode detector.(no tune xtal radio)  Hook it to an unused antenna and drive your phones.  It gives true audio without any electronic modification..A scope completes the package. I  use a pickup loop near the final of the transmitter (more or less loops to tailor the signal into the scope) or another antenna to drive the scope directly.. Good luck..
Bow/KD5KZN
« Reply #8 on: March 16, 2007, 11:36:52 PM »
Thanks for the input everyone.
I guess I'll start out with the basic Diode detector and start dropping coin as my station growth demands it...
« Reply #9 on: March 16, 2007, 11:52:53 PM »
A diode detector is a good way to go. But they will give you a false impression of your audio, at least in reference to how it will sound on the far end of a QSO. The limited bandwidth and reduced SNR of the real world will tend to roll off the highs in your audio. When listening in a diode detector, it's best to make eq your audio so it sounds a little to excessively bright. At this setting, the audio will sound about right through a bandwidth limited receiver on the other end.
Bow/KD5KZN
« Reply #10 on: March 17, 2007, 12:17:53 AM »
Thanks Steve, I'll keep that in mind...
I don't hear any AM on the bands tonight...  Sad
