April 27, 2024, 11:45:00 AM *
Author Topic: UTC S31 choke  (Read 5849 times)
pwfallon
« on: December 05, 2006, 09:56:18 PM »
Anyone have the specs for the UTC S31 Choke??
tnxs,
PW
« Reply #1 on: December 06, 2006, 01:38:32 AM »
Tons of transformer parts catalogs here:
http://208.190.133.201/xfm/index.html
W7IXZ
« Reply #2 on: December 06, 2006, 02:24:10 AM »
UTC S-31 Data.
Filter choke, 20 Henry, 225 MA, 120 Ohms, 2700 volt insulation, G-5 case.
Larry W7IXZ
« Reply #3 on: December 08, 2006, 11:56:44 AM »
Pdub my copy of 1970 catalog says 6H, 225 ma, 100 ohms, 2700 volts. G5 case.
smoothing not a swinger. I think Larry is off by one digit S32 is a swinger 20/4H same current resistance and voltage. fc
W7IXZ
« Reply #4 on: December 08, 2006, 06:07:11 PM »
Here is the scanned page from my UTC catalogue #500.  I hope I do this correctly.
Larry W7IXZ
* UTC Info001.pdf (247 KB - downloaded 259 times.)
« Reply #5 on: December 09, 2006, 09:43:17 AM »
Both S31 and S32 are the same  case, same resistance, same voltage rating so how does one be a swinger and the other 20 h smoothing. I would guess the S31 and S32 have the same core and winding. The only difference is the Gap. S32 has a small gap to get it to 20 H while S31 has a wide gap making it less L and a smoothing.
I think the 1970 catalog is accurate and your PDF has an error based on my design experience.
pwfallon
« Reply #6 on: December 11, 2006, 09:16:48 PM »
Thanks for the info. I measured the inductance and it looks to be ~22H at low signal levels.  I wanted to use it in the screen circuit of the 4x1.
PW
« Reply #7 on: December 12, 2006, 08:42:36 AM »
That sounds like the swinging choke. You could convert it by making the gap wider. Guess there is an error in the 1970 catalog.
Try to put some DC bias on it and remeasure it.
