Ok, this may be simple but just to be sure, to bypass the clipping circuit in a Valiant, I need to:
Remove the 6AL5 clipper tube
Disconnect C83 from R31 and Pin 5 of the 6AL5 clipper socket.
Disconnect C84 from L45
Connect C83 to L45
I've already recapped it with bigger value caps, I guess I should have done this
when I had it on the bench then.
But then I often do things backwards...
