April 29, 2024, 10:06:08 AM *
Author Topic: Removing the Valiant Clipper Circuit.  (Read 3132 times)
Ed/KB1HYS
« on: June 14, 2006, 09:09:12 PM »
Ok, this may be simple but just to be sure, to bypass the clipping circuit in a Valiant, I need to:
Remove the 6AL5 clipper tube
Disconnect C83 from R31 and Pin 5 of the 6AL5 clipper socket.
Disconnect C84 from L45
Connect C83 to L45
I've already recapped it with bigger value caps, I guess I should have done this
when I had it on the bench then.
But then I often do things backwards...  Wink
73 de Ed/KB1HYS
« Reply #1 on: June 19, 2006, 06:57:17 PM »
Ed,
You are almost there.  Roll Eyes
connect the end of  C-83 that was going to  pin 5 to pin 6 of the 6C4.
Disconnect everything that was on pin 6 of the  6C4. You do not want to put your audio through the frequency limiting network of  C-84 and  L-45.
Nice audio from C-83 directly to pin 6 of the 6C4.
Good bye limiter and distortion.
