December 13, 2025, 06:17:45 AM *
Author Topic: Source Needed for Black HV Wire  (Read 7413 times)
« on: May 24, 2006, 02:49:00 PM »
I'm trying to locate a source for the thick, black wire used in high voltage circuits for big transmitters. Outside diameter is roughly the size of a pencil, thick insulation, reminds me of old spark plug wire. W2ILA told me that he found it in red, and I've seen yellow and (I think) blue also, but would prefer to find plain ol' black for a buzzardly project I have.
Someone once suggested a sign shop as a possible source (neon signs, etc) but the only one we had locally closed a number of years ago.
Any ideas? I only need maybe 8-10 feet, but would certainly get more if possible.
Thanks -
~ Todd,  KA1KAQ
Online Online
« Reply #1 on: May 24, 2006, 03:08:22 PM »
Todd,
I used this wire called Packard wire for my current project.  I believe it is spark plug wire with a stranded metal conductor.   I'd give you some but I think I used the last of what was given to me for my radio project.  It's a little thicker than a pencil but it is black.
Try NAPA.  I think they sell bulk spark plug wire so you maybe able to get the lengths you need.  And I think they sell 7mm and 8mm diameters too which is about pencil thickness.
Home of GORT.
2ZE
« Reply #2 on: May 24, 2006, 03:47:06 PM »
My local NAPA store still sells black spark plug wire by the spool. I bought a 100' for 30 bux.
Mike, 2ZE
« Reply #3 on: May 24, 2006, 04:19:39 PM »
Yup good old packard 440 wire, Belden makes it for Napa. Comes in 25 foot spools
All over my big rig
Ed-VA3ES
« Reply #4 on: May 24, 2006, 10:46:25 PM »
http://www.daburn.com/general.html#anchor1
« Reply #5 on: May 25, 2006, 07:11:58 PM »
You might try any place that makes or repairs neon signs
W2XR
« Reply #6 on: May 25, 2006, 11:01:28 PM »
Hi Todd,
I use Packard 440 High Voltage Spark Plug wire or Prestolite High Voltage Spark Plug wire for all of my HV wiring. Any"older" auto parts store should have it in stock, or you can sometimes pick it up real cheap at vintage car swap meets, etc.  It usually runs at retail about $65.00 for a 100 foot roll, but I've seen auto parts stores sell it by the foot at around 6 cents/foot.  For terminal lugs for use with this wire, use the Panduit type PN10-14RX-L for 1/4" studs/screws; PN10-10R-L for no. 10 studs/screws; or PN-10-8R-L for no. 8 studs/screws; you can either solder the Packard wire directly to these terminal lugs, or use a standard Palladin crimp tool, just like Gates did 50 years ago! Newark Electronics sells these Panduit terminals right out of their catalog. These terminals have nylon sleeves that will not melt when heated with a 100W iron, and the solder flows very easily to both the Packard HV wire conductor and the terminal.
Good luck & 73,
Bruce, WA2OGS
« Reply #7 on: May 26, 2006, 10:33:52 AM »
Wowsers! Many, MANY thanks for the information, guys. Makes me feel much better because a.) I thought it looked a lot like spark plug wire and b.) now I know manufacturer names! This stuff is used atop a late 40s broadcast transmitter I'm slowly restoring, and will be one of the final steps to getting it back on the air. At some point in its life, a large, motor-driven Gates rheostat was added to the transmitter for power reduction, which required hacking into the wiring to the big square HV caps. Splicing it back together isn't an option not only because of aestetics, but also because the wire has hardened into rock-like form.
Good to see that Daburn is still around and kicking. I got one of their first catalogs years back, and promptly lost it. An excellent source for ceramic insulators as I recall.
73 and thanks again -
~ Todd  KA1KAQ
« Reply #8 on: May 26, 2006, 10:41:40 AM »
they will send you a new catalog if you ask nice .... klc
« Reply #9 on: May 26, 2006, 10:42:39 AM »
for real short length, try gutting a pic tube, (aka CRT)....
wb1aij
« Reply #10 on: May 26, 2006, 12:34:30 PM »
I have a spool of it that has to be at least 100 feet long. It is a many thin strand  wire about 16 gauge with thick, black, high voltage insulation. Very flexible. I would be happy to send you 15 or 20 feet of this stuff it it would help. No charge. Just send me your address.
Bob Tomlin
WB1AIJ
wb1ai@aol.com
