March 05, 2026, 10:12:02 PM *
Author Topic: panoramoscope to sx-28  (Read 14309 times)
xe1yzy
« on: April 27, 2006, 11:52:36 AM »
Hello Guys,
Well , I found a Nice Panoramascope SA3, and I planning to connect this scope to my Hallicrafters SX-28, (  a really nice match) , so,I need to connect the panoramic adaptor to the plate of the first detector in the SX28 trough a "bloking resistor".
In your opinion, what should be the value of this Blocking resistor, to have the maximun acuracy?
Input frecuency: 455 Khz
Max. Sweepwidht: 200 Khz
My very best regards to all
Pedro XE1YZY.
TVI WHAT TVI?
« Reply #1 on: April 27, 2006, 12:25:47 PM »
If you're going to use it as a panoramic adapter( to view the spectrum) the connection should be made before the 1st amplifier(normally to the plate of the converter tube through a resistor), not at the detector stage.
xe1yzy
« Reply #2 on: April 27, 2006, 01:05:38 PM »
Hi Pete
Well, the Manual of panoramic scope says first detector, this scope is a complete superheterridyne receiver which is periodically tuned over the fixed band of the frecuency spectrum, centered at the intermediate frecuency of the companion receiver (SX-28), but shure ,I can also try the mixer, but the value of the isolation resitor is the doubt.
Regards!
TVI WHAT TVI?
« Reply #3 on: April 27, 2006, 01:06:40 PM »
First detector = converter = mixer.  Second detector is the IF to audio detector.
Pedro, my ARR-7 uses a 100K or so resistor on the plate of the first detector for the panadapter output.  The ARR-7 is roughly equivalent to the SX-28.
The reason for this is so the detector (converter) isn't loaded down by the panadapter.
73 John
xe1yzy
« Reply #4 on: April 27, 2006, 01:20:45 PM »
73 John
Hey Johny!
Nice to "read" you again, thanks for your help, tell me something more please, what should be the right shielded connecting cable?, or just a small lenght coaxial cable works ok?
un abrazo!
73 Pedro
TVI WHAT TVI?
« Reply #5 on: April 27, 2006, 07:42:35 PM »
John said: First detector = converter = mixer.
For some reason, calling the converter or mixer the "first detector" doesn'r ring any bells for me. Can't recall ever calling them a detector.
Anyway Pedeo, I think you got the picture where the panadapter should be connected. With my Panoramic PCA-2, T-200 Panadapter, connected to my National NC-183D, I also used a 100K resistor to the "mixer" plate. A short run of RG-58U coax, about 18 inches, was used to make the connection.
« Reply #6 on: April 27, 2006, 08:33:40 PM »
Hola, Pedro, como te va?  Any shielded cable would probably do OK - RG-58 or RG-59, the shorter the better OM!
Pete - Look in any old Riders manual.  "Frist Detector" was a common usage until the late thirties or so and continued for a while thereafter.  See this one for example: http://www.nostalgiaair.org/PagesByModel/209/M0013209.pdf
73 John
« Reply #7 on: April 27, 2006, 08:59:38 PM »
73 John
Probably why I didn’t recognize it since I generally don’t dabble with radios that era.
« Reply #8 on: April 28, 2006, 08:16:57 AM »
Sheez, Pete, yer an older buzzard than I am... and you have all a them thar manuals to boot  Grin
« Reply #9 on: April 28, 2006, 01:27:22 PM »
Sheez, Pete, yer an older buzzard than I am... and you have all a them thar manuals to boot.
But I'm moving the other way along the technology line.  "Old" doesn't excite me anymore. And, even with all these manuals, I just review them for completeness (all pages as defined) and readability but not for technical or verbal accuracy. I just did a Hammarlund for HQ-120 manual for a customer and they used the “converter” nomenclature.
« Reply #10 on: April 28, 2006, 02:07:05 PM »
In the early days of superheterodyne receivers the "converter" was always refered to as the "first detector". This nomenclature stayed in place for many years. In those days the audio detector was then called the second detector. I have become so used to that terminology that it automatically clicks in my brain. I will usually always say converter or mixer, however if I hear "first detector" my brain automatically translates it inside.
However, the term "converter" usually refers to a self oscilating mixer stage, where
"mixer" usually confers that there is a seperate local oscilator.  Just my $.02 worth.
xe1yzy
« Reply #11 on: April 30, 2006, 01:13:51 PM »
Ok, well, thanks guys, finally the panoramascope are working, and also I learn something about an Old mixers, converters and oscilators, Is usefull for me because, we deal with old radios , but with old books too!
You are a great Guys Thanks!
Pedro XE1YZY
TVI WHAT TVI?
Page created in 0.042 seconds with 15 queries.
