May 07, 2024, 05:21:58 AM *
Author Topic: Now Here's An Antenna System !  (Read 8793 times)
w3bv
« on: February 07, 2006, 11:11:52 AM »
http://www.k9ltn.com/gallery2/main.php?g2_view=core.ShowItem&g2_itemId=1289
« Reply #1 on: February 07, 2006, 12:04:24 PM »
Wow, is that six, 4el 20M Yagis?
I see the call as K9LTN in the photos. I wonder how it worked out for him in 2005?
One potential problem I see is that the horizontal cross boom is close enought to affect the two center Yagi elements. I've had that happen with 6M beams on H frames during modeling and resorted to fiberglass cross booms when using center Yagis like that - three stacked per side.
In additon, the steel guy wires running up and down the vertical supports can have a distortion effect on the pattern. [Unless he used Philly, but looks like steel]
But, what a system.  That is good for 8 db over a single 4el Yagi. Plus, with a shot across that big frozen lake...  He must be a channel master.
I have built, sitting on the ground, a similar system for 6M, but using EIGHT, 4el Yagis. It's big enuff - I can't imagine scaling it up for 20M, over three times the size...
w3bv
« Reply #2 on: February 07, 2006, 12:31:25 PM »
Those are six 4 Element SteppIR tri-band Yagis in that stack. The guy's call is K9LTN
« Reply #3 on: February 07, 2006, 12:35:18 PM »
Man that must be interesting changing bands.
« Reply #4 on: February 07, 2006, 12:36:12 PM »
WOW... SteppIR Yagis.  Now that's worthwhile since he can cover 20-10M and the WARC bands.  Quite the expensive system.
So, it's been at least six months since it's been up.  I'd be curious of any info on performance, mechanical problems, etc.  I'll do a Google and DX Spot search to see.
I notice that someone with big BA's cud actually climb out and replace each Yagi if needed...  Shocked
« Reply #5 on: February 07, 2006, 12:44:54 PM »
I read that it will rotate in elevation too. Moonbounce...   Since it covers 6M too, I guess he wanted that feature.  And to experiment on 20-10M with elevation too.
220' high.  Gotta give the guy credit for his hot passion for the hobby.
k3zrf
« Reply #6 on: February 07, 2006, 04:49:50 PM »
Damn, now that's an antenna farm Shocked
Wonder what the wind load is at let's say 40 MPH?
What is the length of that horizontal piece?
I don't think I have near the property to put up a 'display' like that.
dave/zrf
« Reply #7 on: February 07, 2006, 05:24:31 PM »
Bout how much would that set up go for? 100G's with tower,land ex wife?
« Reply #8 on: February 10, 2006, 06:31:07 PM »
Is this being used on AM ?
« Reply #9 on: February 12, 2006, 12:44:19 PM »
All those antennas, and his audio still sounds like garbage.
W1UJR
« Reply #10 on: February 12, 2006, 06:44:58 PM »
I read somewhere there is a Freudian inverse link between antenna and penis size.
« Reply #11 on: February 16, 2006, 08:03:39 AM »
Bruce here is my 75m antenna.
Comment please.
W1JS
« Reply #12 on: February 16, 2006, 09:14:35 AM »
Say, Paul, that looks like XM not AM.
Wrong end of the alphabet, man!
73 de
W1JS
Jack
No. Weare NH
W1UJR
« Reply #13 on: February 16, 2006, 07:02:22 PM »
Comment please.
Well Paul, looks to me like its lacking BAs.... Shocked
W1ATR
Resident HVAC junkie
« Reply #14 on: February 17, 2006, 02:30:23 PM »
"My dogs' bigger than yerrrr dog"
Seems like an awful pain in the a$$ should one of those little element motors fail.
I wonder what the wind load will be after a few years worth of bird shit stuck to everything. Shocked
Jared W1ATR
Click for radio pix
« Reply #15 on: February 17, 2006, 09:23:37 PM »
I got me some phased Isotrons.
