May 05, 2024, 03:48:05 AM *
Author Topic: Receiver NF and Dynamic Range Spreadsheet for Geeks  (Read 4524 times)
Tom WA3KLR
« on: October 11, 2005, 08:17:26 PM »
Disregard for now.
« Reply #1 on: October 12, 2005, 10:45:59 AM »
Ah RX drag racing can't wait
Tom WA3KLR
« Reply #2 on: October 12, 2005, 01:48:18 PM »
Well,
I hope I'm not opening a can of worms, BUT I made an Excel spreadsheet that calculates and shows receiver dynamic range and noise figure as it progresses through a receiver system design.
The sheet allows 11 stages PLUS a gain reduction via "Input Loss" box at each stage's input.
The spreadsheet also displays the stage-by-stage dynamic range levels on a chart.
The range-reducing stage is quickly identified.
The spreadsheet has 3 pages - click on the "RX Dyn. Range" tab for the DR sheet. It is pre-filled with a dual-conversion receiver design example.
Send me a PM with your e-mail address to get the .xls file which is about 58 kbytes.
« Reply #3 on: October 13, 2005, 12:31:13 PM »
Rob Sherwood has an interesting list of many receivers he has tested.
I trust his numbers and have come within 1 db of his numbers in a couple cases.
You have to remember phase noise will kill close in dynamic range.  fc
Tom WA3KLR
« Reply #4 on: October 28, 2005, 12:25:27 PM »
Frank,
Speaking of receiver drag racing, are you aware of the Analog Devices AD831AP mixer i.c.?
« Reply #5 on: October 28, 2005, 12:37:11 PM »
interesting part but I take notice when the ip3 is above plus 35 dBM.
I'm thinking of playing with some h mode mixers this winter. I want to make close in ip3 as good as my synthesizer phase noise. I'm just starting another 6830 chassis with a cool second mixer module that may come close. I have to modify it a bit but looks cool. I think the dynamic range is around 100 dB at 10 khz spacing with a 20 KHz filter. 105 db above 20 KHz spacing and there is a good 5 to 10 dB of MDS hiding in the board. Might to have to roll my own mixer if this doesn't get me there. 1 KHz spacing is in the mid 80s.
