December 07, 2025, 11:39:36 PM *
Author Topic: Needed - Source for replacement IF Transformer  (Read 3740 times)
W8EJO
« on: July 04, 2005, 03:05:31 PM »
I am attempting to repair an old TMC GPR90. The 3rd IF has a bad 455kc IF transformer and I need  a replacement.
Specs are 95 micro henry;  Can size is H= 2 3/4" x W= 1 3/8" x D= 1 3/8";
Q=82.
Any help would be appreciated.
Terry, W8EJO
ka0pad
« Reply #1 on: July 04, 2005, 03:47:00 PM »
If you cant find one, and your feeling adventurous, you could make one per Harry Lytholl:
http://web.telia.com/~u85920178/blocks/if-txfmr_tube_00.htm
Harry's got a great site to browse.
Larry
WA5VGO
« Reply #2 on: July 04, 2005, 04:57:34 PM »
Are you sure it's not repairable? I've been able to repair almost every bad IFT I've encountered. Check the windings where they terminate. This is a very common failure point. Even if everything looks okay,  reterminate them. Also check the fixed capacitors to be sure they aren't bad. If everthing else fails, get a K-tran replacement and install it in the old can. No one will know the difference.
Good Luck,
Darrell, WA5VGO
Page created in 0.042 seconds with 17 queries.
