February 11, 2026, 02:03:12 PM *
Author Topic: Suggestions for new transmiiter build  (Read 2355 times)
KK7UV
« on: March 27, 2025, 08:05:14 PM »
As I get my A.M. station back together after a year off the air, I would like to try my hand at a Class E build.  I am looking at 10m only, 29.0-29.2 coverage, PWM, and only 100w or so.  I have gone thru the WA1QIX page and am getting a handle on the design aspects, but am needing some help on a couple things to start:
How to select an output device?  Looks like push-pull MOSFETs are the thing, but I'm lost in knowing how to decide.
How do I design the driver and modulator?  All I see are high-power designs and I'm not sure how to scale them down for a 100w P.A.
Thanks for any advice,
Steve KK7UV
« Reply #1 on: March 29, 2025, 07:17:21 AM »
ARF448 in class E.  MRF300 in Class E.
My 10 meter deck uses a 448 in class e.  100 watts carrier 120 percent peaks.
Designed my own modulator and filter from parts of Steve's designs and others.  Ended up with a tx capable of 420 percent positive peaks!
Anywhere, those are the devices I wpuld use.  Bonus, the 448 only takes one device.  Bad part, not made anymore.  A pair of mrf300 or mht1803s will have you right where you want to be, though.  And they are fairly cheap.
And can do 6 meters in the case of the mrf300.
WP2ASS / ex KD6VXI
KK7UV
« Reply #2 on: March 31, 2025, 06:07:28 PM »
Thanks for reply Shane.   I will look into those options.
