August 10, 2026, 03:29:47 PM *
Author Topic: BC-610 tank coil info  (Read 13206 times)
W9BHI
« on: July 25, 2024, 11:48:13 AM »
I am looking for coil information on the C454 1.5 to 2.0 Mhz tank coil. I need to know the turns count on each side of the main tank and the turn count on the moveable link. I have a C-455 coil which is 1.0 to 1.5Mhz. I will be taking turns off of it to bring it up in frequency to match a C-454.
Thanks,
Don W9BHI
WB6NVH
« Reply #1 on: July 25, 2024, 08:29:40 PM »
If I remember correctly, the original "full" set of BC-610 coils, which I once had several of in unused condition, did not have the 160 Meter range coil, it was a separate piece.  This making them somewhat rare. I think there was also a fixed 50 pf vacuum capacitor that was needed with it.
Geoff Fors
Monterey, California
« Reply #2 on: July 26, 2024, 10:57:42 AM »
I've posted this before on another thread but here is the coil data from B&W. I can't remember if the BC-610 used fixed coils or variable coils. I think either will fit thought. It is the "T" coil. The "H" style coil is too big!
Edit: I was thinking of a different rig I use with variable coils. It is indeed the fixed "TL" style coil!
* B&W Coil Data.pdf (291.42 KB - downloaded 224 times.)
pa3hco
« Reply #3 on: August 16, 2024, 02:01:31 PM »
Thanks,
Don W9BHI
[/do you need only the coil information ore {new}coil i have NOS C-454 coil they are dry out but repairablequote]
73pa3hco
W9BHI
« Reply #4 on: August 29, 2024, 09:43:32 AM »
I found someone that has one I could look at Thanks.
n5ama
« Reply #5 on: September 05, 2024, 10:01:53 AM »
Don, I guess my reply didn't make it to the forum and you. I count 23 turns on each side and 6 in the middle.
Tom n5ama
Page created in 0.323 seconds with 18 queries.
