March 12, 2026, 10:57:37 PM *
Author Topic: Globe King 500C  (Read 2119 times)
n5ama
« on: August 23, 2023, 01:35:11 AM »
I’m restoring a Globe King 500C and I’m having some difficulty wi the VFO. I get 300 watts out using a crystal but the rig doesn’t like the VFO when I go from 40m to 20m on the doubler. I’m going to try an external VFO but was wondering if anyone has experienced this problem?
Thanks in advance for any help!
Tom N5AMA
n5ama
« Reply #1 on: August 24, 2023, 09:37:21 AM »
As it turns out, the frequency on the GK500 dial between 20m and 40m is different. GK doubles the 7100 kHz frequency for the 20m band as expected, but the 20m scale doesn’t correspond to double the 40m scale on the vfo. The 20m scale on the vfo dial only occupies the left side of the dial versus the 40m scale that uses the full width of the scale.
The measured frequency is very near what is indicated on the 40m vfo dial. If I use the scale and double the 40m frequency, all is ok but can’t understand why the frequency shift between the 40m and 20m scale on the vfo.
What am I missing here and is there some component in the vfo that isn’t working that would make this frequency shift? I’m confused.
Thanks,
Tom N5AMA
« Reply #2 on: August 24, 2023, 05:39:13 PM »
those globe vfos have several silver mica caps that must  be within tolerance for the vfo to have any accuracy.  I speak from experience with a couple of globe VFOs.. I still use one of them.   I speak of the external type, altho I think they are the same as the ones in the King.  Good luck   Steve
n5ama
« Reply #3 on: August 25, 2023, 08:53:46 AM »
The one I’m using is built in and I plan to use a Collins PTO vfo I built awhile back for a BC-610. I haven’t checked but I suspect the stability isn’t all that great on the GK vfo.
Thanks,
Tom
n5ama
« Reply #4 on: August 29, 2023, 09:17:18 AM »
The vfo works fine, a balky switch and not realizing the doubled vfo frequency was different from what I was expecting. The vfo puts out exactly what it suppose to be doing, it’s just not the doubled 40m signal as I was expecting. Grin
Have a great week,
Tom N5AMA
