5KW+ Bird Dummy Load--Like New
October 01, 2023, 12:31:51 PM *
Author Topic: 5KW+ Bird Dummy Load--Like New  (Read 430 times)
K0UM
« on: May 05, 2023, 03:17:33 PM »
Bird model 8922 50 Ohm Dummy Load--Termaline Coaxial Resistor, model 8922. Rated at 5 KW CONTINUOUS, or up to 54 KW for 1 second!
This unit was purchased new for a professional project and has less than 5 hours of total use. It was used at power levels up to 2 KW for short times. It is in like new condition--near perfect.
The 8922 model has a 1-5/8 inch flanged input connector. I have both the N type and the HN type (female) adapters available--both with the silver plated bullet. The HN type is desirable as it is the Bird 4240-260 which has the traditional Quick Connect connector (like on the Bird 43 wattmeters) so you can swap it out to a type N, UHF, etc every quickly and easily.
The Load is big and heavy and will be costly to ship. I can bring it to Dayton and you can pick it up there for $100--far less than shipping it!
I can't imagine any ham amp that could hurt this load-even your big Gates 5K AM rig! This thing is a powerhouse!
Contact me at jperlick@ariacorp.com
The 8922 NEW price is over $6500 and the adapters are around $500-600 each .
Bird 8922 5KW Load--$2200
Bird 4240-260 1-5/8 flange to HN connector (QC type): $200
Myat 201-059 1-5/8" to Type N female connector adapter: $200
Delivery to Dayton Hamvention: $100
Page created in 0.03 seconds with 18 queries.
