March 15, 2026, 03:18:56 AM *
Author Topic: Central Electronics 20-A no audio on AM  (Read 3317 times)
N7AND
« on: March 26, 2023, 09:29:37 PM »
Hi all I could use some help with my 20a it was working fine and then
 one morning it still had a carrier but no audio on AM only. All other modes
 work as they should. I have checked everything I can think of and still no
 audio on AM. Any help would be much appreciated.
 Thank you Kevin
« Reply #1 on: March 27, 2023, 03:10:24 AM »
 Thank you Kevin
You could explain what it is that you "checked". Tubes? Components? Voltages? etc.?
How about a schematic? Hard to talk about something when you don't have a diagram in front of you.
N7AND
« Reply #2 on: March 27, 2023, 06:11:44 AM »
 Hi Pete
 Well I have check the tubes, caps and I don't see anything
 out of spec. Here is the schematic. I must be missing something
 because It had great modulation on AM before. Thank you for looking.
 73s Kevin
 chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://frank.pocnet.net/instruments/CentralElectronics/20A/PDF2198-01.pdf
* PDF2198-01.pdf (2651.02 KB - downloaded 1355 times.)
K8DI
« Reply #3 on: March 27, 2023, 08:21:08 AM »
If, as you say, it works correctly in all other modes, upper and lower sideband, but no am, then look hard at the mode switch. Since they’re simple to check, check the modulator diodes too.  Pretty much everything needs to be working for the sideband modes to work, the unit does not have separate audio or rf sections for am vs ssb.  If the ssb modes aren’t properly working, then there’s much more to look at…
Ed
« Reply #4 on: March 27, 2023, 10:37:59 AM »
Hi all,
  I wager that modulation transformer TR3 is bad (likely an open primary), and that when running SB1 or SB2, the opposite sideband rejection has been lost.
AJ1G
« Reply #5 on: March 28, 2023, 05:48:18 AM »
Be sure you haven’t inadvertently left the INDICATOR  switch in CARRIER NULL  instead of SET MAX LEVEL.
In CARRIER NULL audio is removed from
the balanced modulator to permit the audio signal from interfering with finding the  deepest null, both audibly in a receiver, and visibly on the RF INDiCATOR cat’s eye tube when adjusting the CARRIER NULL A and B controls.
IIRC, this also removes the audio in the SB1 and SB2 sideband positions of the MODULATION mode switch.  Forgetting to take the INDICATOR switch out of CARRIER NULL has bitten me more than a few times in “Oh crap, where did my audio disappear to?” moments.  Don’t want to sound like Captain Obvious, but figure it’s worth mentioning since I’ve frequently been bitten by this operator error.
BTW, don’t think I’m shouting at you by using all caps when referring to control names and positions.  Standard Navy technical manual convention to use all caps in operating, testing, alignment, and troubleshoot procedures.  Old habits die hard, even in retirement.
Chris, AJ1G
Stonington, CT
N7AND
« Reply #6 on: March 28, 2023, 11:14:51 AM »
 Thank you Chris I don't think I forgot to switch to  SET MAX LEVEL
 but i will check. I saw on the net that a good replacement for TR-2
 and TR-3 is a Hammond 166E12 could I get your guy's opinion on using this transformer?
 Thank you
 Kevin
wa2tak
« Reply #7 on: March 29, 2023, 09:25:55 AM »
Last I heard...Mr. Nick Tusa @ CE-Multiphase has them for sale.
Contact: nick.tusa@ce-multiphase.com
« Reply #8 on: April 03, 2023, 12:43:08 PM »
Some old but good info here:
http://amfone.net/Amforum/index.php?topic=27305.msg241482#msg241482
Page created in 0.027 seconds with 18 queries.
