March 12, 2026, 01:00:38 AM *
Author Topic: Grounding anodized push-up mast  (Read 1967 times)
K6JEK
RF in the shack
« on: February 12, 2023, 01:19:57 PM »
Do I need to ground an anodized, push-up aluminum mast? I can’t figure out how.
It’s a Mastwerks 7 meter mast intended for portable operation. I’d like to leave it up at home for an extended period. The sections are anodized which acts like a thin layer of insulation so the sections are insulated from each other. Scraping away a bit on the bottom section and connecting there would only ground that one section.
Should I just forget about it?  Other stuff is carefully bounded and grounded just like the book says.
« Reply #1 on: February 16, 2023, 12:39:14 AM »
That's pretty light stuff, maybe not good to go drilling into it or anything. Is the inside also anodized?
How about attaching a ground cable to the metal antenna mount up at the top, and hanging it down the mast or zip-tie it, all the way down to the ground stake at the bottom?
https://www.homedepot.com/p/Southwire-25-ft-6-Gauge-Solid-SD-Bare-Copper-Grounding-Wire-10638525/202562793
#6 welding cable is flexible and about $1.75/FT, but it has insulation sure to make a fiery stench when hit by lightning.
Where's all the cheap wire at?
Can't comment on the safety aspects but I'm thinking along the lines of, if it were a wooden or fibergalss mast.
« Reply #2 on: February 16, 2023, 09:09:18 AM »
I used a 40 foot Rohn push up pole for almost a decade.
I didn't worry about grounding it.
I was below the ground carrier wire on all the high volt lines around me.  My 10 meter ground plane was higher than the 4p foot pole (32 footish extended).
I figured it was probably the safest antenna at the house at the time.
WP2ASS / ex KD6VXI
