May 06, 2024, 12:26:43 AM *
Author Topic: Pi network component ratings  (Read 1861 times)
KK7UV
« on: September 10, 2022, 01:00:02 PM »
Moving along on the 813 transmitter project here (pair modulating a pair, ala K1JJ et al)....
Before I start drilling the pi network/output tank deck I need a sanity check on component ratings.
Target operation is 2000v, 250mA, 500w input, 375w output, and so a 4000 ohm plate load and Class C.
I have Tonne's PI-EL design software, which will calculate Vpk and Arms for each tank component, but I need to enter the PEAK PLATE SWING.  For CW or unmodulated carrier I presume this is just 2000v ?   But what do I enter for PEAK PLATE SWING under 100% modulation?   Is it 4000v?
Thanks, Steve
« Reply #1 on: September 10, 2022, 10:09:01 PM »
RMS Plate or Vrms = sqrt(4000ohmsX375Watts) = 1,225Vrms or 1,732Vpeak
Power at 100% Modulation = 1.5X375Watts resting carrier = 562.5Watts
Vrms = sqrt(4,000ohmsX562.5Watts) = 1,500Vrms or 2,121Vpeak
Minimum DC blocking/RF Coupling cap value should be >> 2,000Vdc+2,121Vp RF or ~ 7.5 kV.
How is Tonne defining "Peak Plate Swing?"
Phil
KK7UV
« Reply #2 on: September 11, 2022, 07:08:04 AM »
Thanks Phil.  That is helpful.
Tonne supplies the attached diagram for peak plate swing, but I guess you'd have to derive the value using tube graphs and formulas.
« Reply #3 on: September 11, 2022, 04:11:47 PM »
I think the peak DC plate voltage would be twice the DC supply voltage with 100% plate modulation.  I also think the RF peak voltage would be 4 times the DC plate voltage.  Been a while since I looked at all this so I might be wrong.
K8DI
« Reply #4 on: September 11, 2022, 09:13:10 PM »
If you experiment with the Tonne software, you’ll find that doubling the plate volts doubles the RF voltage.  At 100% modulation, plate voltage is doubled.  So is current.  Whatever it says for carrier, double the numbers and those will be the 100% modulated numbers…
Ed
« Reply #5 on: September 12, 2022, 06:51:34 AM »
I've used Jim's software before.  Works out pretty good, just need to account for strays.
I used the G3SEK spreadsheet more.  It allows for more granular input of strays, etc.
Both good, get you where you need to be.
The G3SEK spreadsheet needs a spreadsheet installed.  Cool thing is, Google sheets works fine, so it will run on the phone!
WP2ASS / ex KD6VXI
