All Rally submissions sorted by points.Note: States = US States + Canadian Provinces + Other Countries: NE5TX: category: A, 137 contacts, 26 states, score: 163 W4GUZ: category: G, 95 contacts, 31 states, score: 126 W1OC: category: C, 76 contacts, 27 states, score: 103 W4GON: category: B, 73 contacts, 26 states, score: 99 K3FEF: category: D, 65 contacts, 27 states, score: 92 WA1QIX: category: D, 75 contacts, 16 states, score: 91 W4SVA: category: A, 55 contacts, 22 states, score: 77 K8JLY: category: M, 54 contacts, 22 states, score: 76 W2XR: category: B, 55 contacts, 19 states, score: 74 AG5CK: category: I, 55 contacts, 14 states, score: 69 W3MMR: category: I, 46 contacts, 22 states, score: 68 W9GT: category: H, 43 contacts, 20 states, score: 63 WZ8J: category: A, 44 contacts, 18 states, score: 62 N1MUC: category: A, 42 contacts, 15 states, score: 57 W1EQX: category: I, 39 contacts, 17 states, score: 56 W0ARM: category: C, 34 contacts, 10 states, score: 44 AC7DA: category: A, 32 contacts, 11 states, score: 43 KM4XG: category: I, 26 contacts, 16 states, score: 42 KC2ZYL: category: C, 25 contacts, 14 states, score: 39 W5MW: category: A, 33 contacts, 5 states, score: 38 W5MW: category: A, 33 contacts, 5 states, score: 38 KA4KOE: category: C, 25 contacts, 12 states, score: 37 W9JXN: category: A, 24 contacts, 13 states, score: 37 WD4LUR: category: A, 22 contacts, 14 states, score: 36 WA1MTZ: category: H, 26 contacts, 9 states, score: 35 K0ARA: category: A, 24 contacts, 10 states, score: 34 N4WD: category: A, 22 contacts, 10 states, score: 32 WA2SQQ: category: 1, 20 contacts, 11 states, score: 31 W1IA: category: D, 18 contacts, 12 states, score: 30 WA1LGQ: category: B, 21 contacts, 9 states, score: 30 W0PWE: category: D, 19 contacts, 8 states, score: 27 WA1SOV: category: G, 16 contacts, 11 states, score: 27 KA9UVY: category: C, 17 contacts, 9 states, score: 26 N9PVF: category: A, 18 contacts, 8 states, score: 26 KB1UGN: category: J, 15 contacts, 6 states, score: 21 K9FH: category: C, 10 contacts, 7 states, score: 17 WZ8J: category: A, 9 contacts, 8 states, score: 17 KC9HFR: category: D, 9 contacts, 7 states, score: 16 W2ENY: category: C, 10 contacts, 6 states, score: 16 N2BE: category: A, 8 contacts, 6 states, score: 14 K3KE: category: C, 7 contacts, 6 states, score: 13 KA1SHU: category: B, 7 contacts, 6 states, score: 13 KC8ZUL: category: G, 7 contacts, 6 states, score: 13 N5KWD: category: C, 5 contacts, 5 states, score: 10 NA1S: category: A, 6 contacts, 4 states, score: 10 KC1JZR: category: C, 5 contacts, 4 states, score: 9 AA1WD: category: A, 4 contacts, 4 states, score: 8 KC8AAF: category: A, 5 contacts, 3 states, score: 8 K9FAA: category: A, 4 contacts, 3 states, score: 7 K8DI: category: C, 3 contacts, 3 states, score: 6 W8KHK: category: B, 3 contacts, 3 states, score: 6 WK4K: category: A, 3 contacts, 3 states, score: 6 N3XKB: category: C, 3 contacts, 2 states, score: 5 KD2BDA: category: C, 2 contacts, 2 states, score: 4 N4JOW: category: C, 2 contacts, 2 states, score: 4 KC8ZUL: category: G, 1 contacts, 1 states, score: 2 W1VCM: category: A, 1 contacts, 1 states, score: 2 WA3FIR: category: C, 1 contacts, 1 states, score: 2 WB0IIS: category: C, 1 contacts, 1 states, score: 2 WE3ST: category: C, 1 contacts, 1 states, score: 2Categories:A = Vacuum Tube Commercial AM Amateur Equipment (KW1, 32V3, DX-100, etc.)B = Home brew largely vacuum tube transmitterC = Commercially built solid state transmitterD = Home brew solid state transmitterE = Hybred (solid state and tubes) commercially built transmitting equipmentF = Hybred (solid state and tubes) home builtG = Converted AM Broadcast transmitterH = Military transmitting equipmentI = Software Based (SDR) Flex, Anan, etc.J = Category not specifiedPower Levels:1 = 5 Watts or Less (QRP)2 = Greater than 5, through 30 Watts3 = Greater than 30, through 100 Watts4 = Greater than 100, through 250 Watts5 = Greater than 250 Watts, up to the FCC legal limitCategories and power levels are combined to create a station class. Example: B5 = Vacuum tube home built running 250 watts up to the legal limit.Submissions sorted by category, then by points:Category A5: W4SVA, 77 points WZ8J, 62 points N1MUC, 57 points AC7DA, 43 points WD4LUR, 36 points WZ8J, 17 points NA1S, 10 pointsCategory A4: W5MW, 38 points W5MW, 38 points K0ARA, 34 points N9PVF, 26 points AA1WD, 8 points KC8AAF, 8 points K9FAA, 7 pointsCategory A3: NE5TX, 163 points W9JXN, 37 points N4WD, 32 points N2BE, 14 points K8JLY, 12 pointsCategory A2: WK4K, 6 points W1VCM, 2 pointsCategory B5: W2XR, 74 points K8JLY, 20 points KA1SHU, 13 points W8KHK, 6 pointsCategory B4: W4GON, 99 points K8JLY, 30 pointsCategory B3: K8JLY, 25 pointsCategory B1: WA1LGQ, 30 pointsCategory C5: W0ARM, 44 points K3KE, 13 points N5KWD, 10 points KC1JZR, 9 points N3XKB, 5 pointsCategory C4: W1OC, 103 points KA4KOE, 37 points K9FH, 17 points W2ENY, 16 points WE3ST, 2 pointsCategory C3: K8DI, 6 pointsCategory C2: KC2ZYL, 39 points KA9UVY, 26 points KD2BDA, 4 points N4JOW, 4 points WA3FIR, 2 points WB0IIS, 2 pointsCategory D5: K3FEF, 92 points W1IA, 30 points KC9HFR, 16 points WA1QIX, 91 points <- Event organizerCategory D2: W0PWE, 27 pointsCategory E0:Category F0:Category G5: W4GUZ, 126 points WA1SOV, 27 points KC8ZUL, 13 points KC8ZUL, 2 pointsCategory H5: W9GT, 63 pointsCategory H3: WA1MTZ, 35 pointsCategory I5: AG5CK, 69 pointsCategory I4: W3MMR, 68 points W1EQX, 56 pointsCategory I3: KM4XG, 42 pointsTotal unique calls logged: 604Special event calls logged:Total Contacts Logged: 1545Percentage Contacts by band: 160 Meters: 3.95 80 Meters: 49.13 40 Meters: 42.01 20 Meters: 0.26 15 Meters: 4.08 10 Meters: 0.39 6 Meters: 0.19
