April 25, 2024, 06:02:49 PM *
Author Topic: *PRELIMINARY* 2022 AM Rally Results  (Read 1887 times)
« on: February 28, 2022, 11:51:57 AM »
NOTE: This is preliminary data!
This is the state of the AM Rally as I know of it.  There may be missing logs, etc. which can and would most likely change the results.
If you have a log and have not sent it in, please do so ASAP so your results can be counted.
Please look this over.  If you sent in a log, and your call is not on this list, please contact me !.
All Rally submissions sorted by points.
Note: States = US States + Canadian Provinces + Other Countries:
     NE5TX: category: A, 137 contacts,  26 states, score: 163
     W4GUZ: category: G,  95 contacts,  31 states, score: 126
      W1OC: category: C,  76 contacts,  27 states, score: 103
     W4GON: category: B,  73 contacts,  26 states, score:  99
     K3FEF: category: D,  65 contacts,  27 states, score:  92
    WA1QIX: category: D,  75 contacts,  16 states, score:  91
     W4SVA: category: A,  55 contacts,  22 states, score:  77
     K8JLY: category: M,  54 contacts,  22 states, score:  76
      W2XR: category: B,  55 contacts,  19 states, score:  74
     AG5CK: category: I,  55 contacts,  14 states, score:  69
     W3MMR: category: I,  46 contacts,  22 states, score:  68
      W9GT: category: H,  43 contacts,  20 states, score:  63
      WZ8J: category: A,  44 contacts,  18 states, score:  62
     N1MUC: category: A,  42 contacts,  15 states, score:  57
     W1EQX: category: I,  39 contacts,  17 states, score:  56
     W0ARM: category: C,  34 contacts,  10 states, score:  44
     AC7DA: category: A,  32 contacts,  11 states, score:  43
     KM4XG: category: I,  26 contacts,  16 states, score:  42
    KC2ZYL: category: C,  25 contacts,  14 states, score:  39
      W5MW: category: A,  33 contacts,   5 states, score:  38
    KA4KOE: category: C,  25 contacts,  12 states, score:  37
     W9JXN: category: A,  24 contacts,  13 states, score:  37
    WD4LUR: category: A,  22 contacts,  14 states, score:  36
    WA1MTZ: category: H,  26 contacts,   9 states, score:  35
     K0ARA: category: A,  24 contacts,  10 states, score:  34
      N4WD: category: A,  22 contacts,  10 states, score:  32
    WA2SQQ: category: 1,  20 contacts,  11 states, score:  31
      W1IA: category: D,  18 contacts,  12 states, score:  30
    WA1LGQ: category: B,  21 contacts,   9 states, score:  30
     W0PWE: category: D,  19 contacts,   8 states, score:  27
    WA1SOV: category: G,  16 contacts,  11 states, score:  27
    KA9UVY: category: C,  17 contacts,   9 states, score:  26
     N9PVF: category: A,  18 contacts,   8 states, score:  26
    KB1UGN: category: J,  15 contacts,   6 states, score:  21
      K9FH: category: C,  10 contacts,   7 states, score:  17
      WZ8J: category: A,   9 contacts,   8 states, score:  17
    KC9HFR: category: D,   9 contacts,   7 states, score:  16
     W2ENY: category: C,  10 contacts,   6 states, score:  16
      N2BE: category: A,   8 contacts,   6 states, score:  14
      K3KE: category: C,   7 contacts,   6 states, score:  13
    KA1SHU: category: B,   7 contacts,   6 states, score:  13
    KC8ZUL: category: G,   7 contacts,   6 states, score:  13
     N5KWD: category: C,   5 contacts,   5 states, score:  10
      NA1S: category: A,   6 contacts,   4 states, score:  10
    KC1JZR: category: C,   5 contacts,   4 states, score:   9
     AA1WD: category: A,   4 contacts,   4 states, score:   8
    KC8AAF: category: A,   5 contacts,   3 states, score:   8
     K9FAA: category: A,   4 contacts,   3 states, score:   7
      K8DI: category: C,   3 contacts,   3 states, score:   6
     W8KHK: category: B,   3 contacts,   3 states, score:   6
      WK4K: category: A,   3 contacts,   3 states, score:   6
     N3XKB: category: C,   3 contacts,   2 states, score:   5
    KD2BDA: category: C,   2 contacts,   2 states, score:   4
     N4JOW: category: C,   2 contacts,   2 states, score:   4
    KC8ZUL: category: G,   1 contacts,   1 states, score:   2
     W1VCM: category: A,   1 contacts,   1 states, score:   2
    WA3FIR: category: C,   1 contacts,   1 states, score:   2
    WB0IIS: category: C,   1 contacts,   1 states, score:   2
     WE3ST: category: C,   1 contacts,   1 states, score:   2
Categories:
A = Vacuum Tube Commercial AM Amateur Equipment (KW1, 32V3, DX-100, etc.)
B = Home brew largely vacuum tube transmitter
C = Commercially built solid state transmitter
D = Home brew solid state transmitter
E = Hybred (solid state and tubes) commercially built transmitting equipment
F = Hybred (solid state and tubes) home built
G = Converted AM Broadcast transmitter
H = Military transmitting equipment
I = Software Based (SDR) Flex, Anan, etc.
J = Category not specified
Power Levels:
1 = 5 Watts or Less (QRP)
2 = Greater than 5, through 30 Watts
3 = Greater than 30, through 100 Watts
4 = Greater than 100, through 250 Watts
5 = Greater than 250 Watts, up to the FCC legal limit
Categories and power levels are combined to create a station class.
   Example: B5 = Vacuum tube home built running 250 watts up to the legal limit.
Submissions sorted by category, then by points:
Category A5:
     W4SVA,  77 points
      WZ8J,  62 points
     N1MUC,  57 points
     AC7DA,  43 points
    WD4LUR,  36 points
      WZ8J,  17 points
      NA1S,  10 points
Category A4:
      W5MW,  38 points
      W5MW,  38 points
     K0ARA,  34 points
     N9PVF,  26 points
     AA1WD,   8 points
    KC8AAF,   8 points
     K9FAA,   7 points
Category A3:
     NE5TX, 163 points
     W9JXN,  37 points
      N4WD,  32 points
      N2BE,  14 points
     K8JLY,  12 points
Category A2:
      WK4K,   6 points
     W1VCM,   2 points
Category B5:
      W2XR,  74 points
     K8JLY,  20 points
    KA1SHU,  13 points
     W8KHK,   6 points
Category B4:
     W4GON,  99 points
     K8JLY,  30 points
Category B3:
     K8JLY,  25 points
Category B1:
    WA1LGQ,  30 points
Category C5:
     W0ARM,  44 points
      K3KE,  13 points
     N5KWD,  10 points
    KC1JZR,   9 points
     N3XKB,   5 points
Category C4:
      W1OC, 103 points
    KA4KOE,  37 points
      K9FH,  17 points
     W2ENY,  16 points
     WE3ST,   2 points
Category C3:
      K8DI,   6 points
Category C2:
    KC2ZYL,  39 points
    KA9UVY,  26 points
    KD2BDA,   4 points
     N4JOW,   4 points
    WA3FIR,   2 points
    WB0IIS,   2 points
Category D5:
     K3FEF,  92 points
      W1IA,  30 points
    KC9HFR,  16 points
    WA1QIX,  91 points <- Event organizer
Category D2:
     W0PWE,  27 points
Category E0:
Category F0:
Category G5:
     W4GUZ, 126 points
    WA1SOV,  27 points
    KC8ZUL,  13 points
    KC8ZUL,   2 points
Category H5:
      W9GT,  63 points
Category H3:
    WA1MTZ,  35 points
Category I5:
     AG5CK,  69 points
Category I4:
     W3MMR,  68 points
     W1EQX,  56 points
Category I3:
     KM4XG,  42 points
Total unique calls logged: 604
Special event calls logged:
Total Contacts Logged: 1545
Percentage Contacts by band:
  160 Meters: 3.95
   80 Meters: 49.13
   40 Meters: 42.01
   20 Meters: 0.26
   15 Meters: 4.08
   10 Meters: 0.39
   6 Meters: 0.19
« Reply #1 on: February 28, 2022, 12:09:04 PM »
I see that W5MW was processed twice.  I'll fix that in the final results.
W0ARM
« Reply #2 on: March 25, 2022, 03:26:13 PM »
Howdy,
Had lots o' fun participating in the AM Rally this year... This was my first, but definitely won't be my last!  I was only able to get in on the last day and last few hours this year, but still had a blast.  What a cool event...
When will the official results be posted, and will they be posted somewhere on the "AM Rally" homepage?
Thanks & 73,
~Alan
W0ARM
PS: New to the AMfone forum also, so thanks for being there!
~A
« Reply #3 on: March 25, 2022, 05:05:01 PM »
Yes, the official results will be posted shortly.  Currently generating the certificates for the winners (yes the certificates are BACK!).  The results are pretty much the same as the prelim results.  I don't think any other logs came in after I generated the prelim results.
