April 26, 2024, 03:50:55 AM *
Author Topic: UTC Mod xfrmr S-22 ratings  (Read 3685 times)
WB6VHE
« on: May 19, 2005, 04:00:07 PM »
Greetings!
Does anyone have, or know where to get,  the specs (max voltage, current,
etc) for the UTC S-22 mod xfrmr?  I got the connection info from amwindow
website, but haven't been able to find anything else.  A copy of a spec sheet
would be wonderful!
Thanks in advance, and
Ed - N3LHB
« Reply #1 on: May 19, 2005, 10:06:34 PM »
I have a few copies of UTC catalogs, the only spec's mentioned for the S-22 is that it is a 250 watt mod transformer, no specs on max DC volts or current.
It does mention that the secondary "carries class c current" (no value), so whatever 500 watts works out to be on your final would be the limit of ma that the secondary permits, since mod power is usually half of the carrier.
WA1LGQ
« Reply #2 on: May 20, 2005, 10:14:08 PM »
This may or may not be helpful, but here you go........Larry
WB6VHE
« Reply #3 on: May 24, 2005, 01:31:33 PM »
Thanks to all who replied!  Larry, yes, very useful!  At least I know the xfrmr is rated
at 2 kV; plus, specs for other tubes also interesting.
Thanks again!
