May 11, 2024, 04:27:47 PM *
Author Topic: 75 Ohm coax to 100 Ohm balanced receive balun  (Read 2553 times)
« on: June 06, 2021, 11:04:33 PM »
Anyone make an animal like this for HF with low loss?
I have an amplified loop with a 75-Ohm output, and would like to feed it into one of my vintage Super-Pro 200's.
« Reply #1 on: June 07, 2021, 02:31:28 PM »
I really wouldn't worry about a 1.3 mis-match but a 8 turn primary and 10 turn secondary on a 50-2 core should work just fine.
« Reply #2 on: June 07, 2021, 03:10:19 PM »
Thanks, I'll get busy. Wink
« Reply #3 on: June 07, 2021, 11:50:19 PM »
8:10 turns PRI to SEC, turns ratio of 1.25, but wouldn't the Z ratio would be that squared, or 1.5625 giving 117 Ohms.
For  a Z ratio of 1.25, turns ratio might more closely be the SQRT if it, or 1.12.
How about 10:12 - 10 turns primary and 12 turns secondary?
Check me if this is correct math.
« Reply #4 on: June 08, 2021, 11:29:59 AM »
You're probably closer Pat but with the broadbandedness(?) of that core I don't think it's worth haggeling!  Grin
« Reply #5 on: June 09, 2021, 12:07:54 AM »
I think you are right.
