April 26, 2024, 03:58:37 AM *
Author Topic: 6:1 Balun on Globe King output ??  (Read 5078 times)
nq5t
« on: May 15, 2005, 01:22:35 PM »
Somewhere, and I think it was here, there was a posting some time ago about the use of a 6:1 balun (6:1-HB/U300) on the output of a Globe King.  The idea was to connect the 300 ohm side to the existing antenna output to provide a "friendlier" match for 50 ohm antennas to the the King's output tank.
Can't find it with a search, and perhaps may be mistaken where I saw it.  I have a question about it.  Anyone recall or know anything about this?
Thanks ... Grant/NQ5T
« Reply #1 on: May 15, 2005, 03:37:23 PM »
Check your email Grant
« Reply #2 on: May 15, 2005, 04:38:51 PM »
The way I understand it is that you only need the 6:1 balun when using the Chump on 160M. All other frequencies, it will load 50Ω easily.
« Reply #3 on: May 15, 2005, 07:26:11 PM »
Using the balun makes the tuning on 75 much smoother and easier.  160 and 75 are the ones.  Rest is normal.
« Reply #4 on: May 15, 2005, 07:46:28 PM »
Yeah. Now all I have to do is get a LV transformer for mine and I'll be back in business. Unfortunatly, I think I'm going to have to bite the bullet and buy one from Peter Dahl.
nq5t
« Reply #5 on: May 15, 2005, 07:59:46 PM »
Quote from: W3SLK
I'm told that the L/C ratio in the GK500 final tank is also better suited to a higher Z load on 75/80.  Have balun ... just want to try it out. :-)
I got the information I was looking for in the original post, by the way.
« Reply #6 on: May 15, 2005, 09:36:38 PM »
Quote from: W3SLK
Check Gary, WZ1M for a rewind.  He did the LHV transformer for mine and he was less expensive.
http://tubes_tubes_tubes.tripod.com/tubestubestubes/id33.html
Email for a quote.  No contact excpet I used him because Dahl and Heyborer cost much more.
