November 26, 2025, 08:14:21 AM *
Author Topic: VE3ELQ modulator board UPDATE  (Read 2858 times)
km6sn
« on: December 07, 2019, 04:13:06 PM »
update 1/3/20
Andy, ND8D has graciously shared his PCB  layouts for Nigel's PWM generator
and PWM driver. With this board set you can make a complete modulator.
The PWM generator is      https://oshpark.com/shared_projects/Dw1PsRCf
and the PWM driver is      https://oshpark.com/shared_projects/E39m7Eaa
Many thanks to Andy for his generous contribution to the art.
Rod KM6SN
...... end update
After struggling with KICAD to make a VE3ELQ PWM board, I discovered
deeply buried in some of these posts that OSHPARK has ready-made
boards for Nigel's modulator, courtesy of ND8D (thanks ND8D).
ND8D
« Reply #1 on: December 07, 2019, 06:25:39 PM »
Hello!
I forgot about that PWB on OHSPARK. I would not recommend ordering it since I got the wrong footprint for the IR2110S on there and it is a royal pain to make work.
I have since iterated that design into two seperate boards, a MiniPWM and PWM_Driver, One is for low level PWM generation and the other for driving the half bridge.
MiniPWM:
PWM Driver:
I have some larger boards made but they are not economical to run through OSH park. For example. I have a PWM driver board with the filter integrated on board, a more advanced PWM modulator board with an arduino and VFO on board, and a handful of PA designs.
Most of these I run through board houses that require a minimum order of 10, so I have extra bare boards I can sell for the cost of shipping!
73's
ND8D
km6sn
« Reply #2 on: December 07, 2019, 10:36:08 PM »
Andy, Thanks for the reply. I appreciate the help. Rod
N4LTA
« Reply #3 on: December 08, 2019, 10:59:16 AM »
I have my own layout that I am building just for me. I would  not make Nigel's work available other than doing a project for myself unless he approved. I hope that he approved yours.
On my version,  I separated the output board and the PWM drive. Working on a 400 watt 75 meter rig now.
The PWM generator is a surface mount board and the output board is through hole single sided. Doing some testing now
Pat
N4LTA
M0VRF
« Reply #4 on: December 08, 2019, 06:28:49 PM »
Simples
About an inch square.
https://644db4de3505c40a0444-327723bce298e3ff5813fb42baeefbaa.ssl.cf1.rackcdn.com/f4cc61755d341eb6b4f0b2f6c4c7fbef.png
Page created in 0.046 seconds with 18 queries.
