February 07, 2026, 06:35:01 AM *
Author Topic: Problem With Post  (Read 21588 times)
W9ZSL
« on: May 07, 2019, 02:11:52 PM »
I started a thread in Technical regarding Driver Transformer Ratios. I wrote a reply and added some info including diagrams and a pix of the monitor. Must have done something wrong because I'm "locked out" of the topic. When I click on it, all I get is a blank screen.  Mike W9ZSL
KK4YY
« Reply #1 on: May 07, 2019, 03:29:13 PM »
Same here. Blank page.
« Reply #2 on: May 07, 2019, 06:51:00 PM »
I answered to put 2660 Ohms across each half of the secondary if using 325V and expecting 12K plate to plate load. But that's gone as well.
W9ZSL
« Reply #3 on: May 08, 2019, 11:29:37 AM »
Since the test calls for using the entire secondary, I figured out that 5K plus a 20 ohm wire-wound pot would do the job. One leg of the pot and one side of the secondary is grounded. All I have to do is lift the center tap from ground and plug in the resistor/pot combo and that should do it! Thanks!
« Reply #4 on: May 09, 2019, 05:41:21 PM »
Guys, sorry about this.  No idea what happened or why; it has happened before but very rarely.  No way to recover the thread that we know of.
I deleted the thread, suggest you re-start it.
W9ZSL
« Reply #5 on: May 10, 2019, 12:01:13 PM »
Probably something I did when trying to make attachments. This happened once before. At any rate, problem is solved. I found a 5K, 20 watt resistor that should work just fine for the test of the driver.  73!
Page created in 0.086 seconds with 18 queries.
