March 04, 2026, 01:10:58 AM *
Author Topic: ICOM 7610  (Read 3418 times)
K1ETP
« on: December 04, 2018, 10:52:53 AM »
Does anyone have any experience with the Icom 7610 on AM? Is it's transmit limited to 6 KHz like the 7300 or is the transmit bandwidth adjustable via menu to more than 6 KHz??
Rich K1ETP
KC2TAU
« Reply #1 on: December 04, 2018, 12:16:42 PM »
Hello Rich,
I took a look through the manual and the options and layout seem very similar to the IC-7300. The widest transmit bandwidth on SSB seems to be the same at 100-2900hz which leads me to believe the AM bandwidth is the same as the IC-7300. There are reports that receive audio on AM is better than the IC-7300 which rolled off everything below 200hz but I have not listened to an IC-7610 to confirm this.
N4LQ
« Reply #2 on: March 23, 2023, 03:21:32 PM »
On the 7610, AM rolls off abruptly at 300 hz unlike the 7300 which does so at 150 hz.
AM sounds better on the 7300 Embarrassed Embarrassed Cry
I can find nothing in the hidden menu to correct this.
Feeding AF into the ACC input has the same result.
Page created in 0.042 seconds with 17 queries.
