May 16, 2026, 02:00:26 AM *
Pages: 1 ... 4 [5]   Go Down
Author Topic: Analog modulating a 1000 watt carrier class E rig  (Read 116090 times)
ka1tdq
« Reply #100 on: September 28, 2019, 01:48:48 PM »
It's funny but I'm almost a step ahead of you. I already have the bucket and it'd be easy just to add salt water!
Actually, I was using the bucket was for secondary containment.
I stopped at HRO this morning and got 100' of LMR400. I'll install it tomorrow. My kid's birthday party today.
Jon
ka1tdq
« Reply #101 on: September 28, 2019, 07:31:07 PM »
...and I let the smoke out. I'm not sure of exactly what, but it looks like one of the drivers. I'm thinking the problem all along was parasitics.
I replaced my antenna feed line with a near perfect SWR, tuned up at 300 watts with a nice safe waveform, unkeyed... When I keyed up again the waveforms were completely scattered with smoke coming from something.
I'm thinking I should've put those 300 ohm resistors inline with each driver.
Jon
w8khk
« Reply #102 on: September 29, 2019, 01:36:41 AM »
You might want to consider adding one of these:
http://www.classeradio.com/efficiency_meter_rev_f.pdf
ka1tdq
« Reply #103 on: September 29, 2019, 10:13:12 AM »
The 5-meter method does just as well.
At some point I'll pull the heat sink assembly, replace the damaged components and put in some parasitic suppression.
Jon
w8khk
« Reply #104 on: September 29, 2019, 10:37:32 AM »
The idea here is that the QIX board monitors AND SHUTS DOWN immediately upon overload.  No human can respond to an overload that quickly while monitoring meters visually.  The alternative: ordering from Mouser or Digi-key and soldering OFTEN.  Certainly worth a careful look at this option.
ka1tdq
« Reply #105 on: September 29, 2019, 11:34:28 AM »
Oh
« Reply #106 on: October 02, 2019, 12:43:46 AM »
Ugh! Oily cantennas!! You'd think Heathkit could have offered something with a bellows.
« Reply #107 on: October 02, 2019, 10:46:35 PM »
Jon
Yes, those resistors have to be there, or the likelyhood of parasitics is quite high.
ka1tdq
« Reply #108 on: October 03, 2019, 09:49:29 AM »
It'll require a rebuild of the heat sink assembly.
Something to note, the transzorbs protected two of four mosfet modules. Once I cut out the transzorbs, the dead short went away from the drain bus for those two modules. Something else went as well with the remaining two modules.
After all this, I still had a sporadically fluctuating SWR problem when using my rice box. I had a coax splice in the shack that was intermittently making connection. I could shake the coax at the splice and SWR would jump all over the place. Once I put a new connector on, the problem went away. I'm sure this contributed to the parasitic problem as well.
It's a shame though to blow up a rig over a PL-259.
Jon
ka1tdq
« Reply #109 on: October 03, 2019, 07:45:50 PM »
Actually I take that back. I forgot that I installed two transzorbs per mosfet module. Once I cut them all out and did resistance checks, I realized that the drains were protected. So, all seems ok and I'll just need to solder on more transzorbs.
But, in the time since I thought I blew up my class E rig, I converted my 75 meter dipole into a 40 meter delta loop and bought an Icom 7300. What a nice rig!
Jon
ka1tdq
« Reply #110 on: November 01, 2019, 02:44:33 PM »
I figured out a way to solder new Transzorbs in place without disassembling the heat sink. I have ground connections on either side of the heat sink. I can just pre-solder the ground side of the Transzorbs onto a solid piece of #12 wire, in the correct positions, and slide it in place over the drain buses. The wire would be connected to the grounds on either side and then I'd just need to solder the other end of the Tranzorbs onto the drain buses.
The problem was that the area between the heat sink and transformer assemblies is tight, without much room to sneak a soldering iron in.
Once I do this, I can resume testing.
I needed some new inspiration.
Jon
Pages: 1 ... 4 [5]   Go Up
Page created in 0.029 seconds with 19 queries.
