April 26, 2024, 01:47:34 PM *
Author Topic: FS: JOHNSON RANGER II (Slightly Modified !!)  (Read 1556 times)
W1KSZ
« on: November 22, 2018, 09:58:50 AM »
This poor fellow was the victim of a real hack job. The Function Switch
died (a common occurrence if you "Hot Switch" it). The previous owner
then re-wired it so it works on AM (no CW). Then he drilled a big "honkin"
hole in the front panel to fit a big, ugly toggle switch.
So, I obtained a clean Function Switch, wired it so at least it turns on and
patched the big, ugly hole with JB Weld. The Front Panel needs re-painting
and re-stenciling. The PTT Mod has been done. I have also replaced the VFO
Coupler insulator with a G-10 Epoxy Board 4 point insulator. Every Ranger
I have seen has had the old Phenolic Insulator damaged or non-functioning.
All Tubes were tested on a TV-7 Tube Tester and all bad tubes were replaced.
A number of old Electrolytics were also replaced.
It puts out about 48 Watts (measured on my Bird 4391 Digital Wattmeter).
The Audio sounds fine. Basically you have a working Johnson Ranger II AM
Transmitter.
I leave the re-wiring of the Function Switch to the next owner, should he choose
to do so, but it's not necessary if AM is your only Mode.
I will include a rather large volume containing the Operating Manual, the
Assembly Manual and everything I could find on the Web about modifications.
This being a project Radio is definitely sold "As-Is".
Asking price is $150, pick-up only in Vail. Shipping would cost a lot !!
