March 07, 2026, 01:02:18 AM *
Author Topic: CLASS D or CLASS E: Which One Should I Choose  (Read 12625 times)
W1KSZ
« on: April 12, 2018, 09:43:25 PM »
I am getting more serious about building a Class D or E AM Transmitter, something in the 300 Watt avg range.
Before I can get started, I need to decide which Class to build, D or E.
What are the advantages of one over the other ? Which one should I choose and why ?
Also, after deciding, I will need a source of DIY info, schematics, pictures, etc.
Thanks for your help,
73, Dick, W1KSZ
W1KSZ
« Reply #1 on: April 12, 2018, 09:47:33 PM »
My bad guys, I forgot I had a similar question earlier. Old age is a ^&*%*&.
73, Dick, W1KSZ
« Reply #2 on: April 13, 2018, 09:58:54 AM »
I don't know a source for class D but Steve WA1QIX has about all could want for your edification.
http://www.classeradio.com/
M0VRF
« Reply #3 on: April 13, 2018, 03:04:32 PM »
I use Class D/E or that's what I think it is has class E waveforms with class D B/W = >1MHz on 40m.
If you stick to the design by VE3ELQ using the SiC FETs from Cree you'll be fine.
My version uses 4 GaN Fets and runs 100W carrier with 500W peaks with a 48V PSU.
Pic attached.
n1ps
« Reply #4 on: April 15, 2018, 08:14:05 PM »
For Class E, go with the QIX designs.  Bulletproof and probably more than 100 have been built.  Steve gives you complete designs including the modulator (PWM) and even a VFO.
For Class D you can also look at Jay W1VD site.  He has some nice designs.  He recommends the QIX PWM I believe.
Either way these projects are intensive and take time  Wink.  I think it took me about a year to put together a class E project.  But well worth the effort IMHO.
Peter
« Reply #5 on: April 15, 2018, 09:10:03 PM »
It is possible to build a complete transmitter from the ground up, in about a month.  But of course it won't be a pretty as the one Pete (N1PS) built  Wink
« Reply #6 on: April 17, 2018, 11:13:03 AM »
I noticed your post in "Wanted".
If you can populate a PC board, you can pretty likely build Steve's design.
A lot of folks have built these successfully with 'limited' skills.
Doesn't matter what the end product looks like, only matters that it works :-)
If there are certain parts that you decide you can't, or don't want to attempt, there are a few people around who can help you out as well.
Either by advice here, by email, or even putting together parts for you.
« Reply #7 on: April 17, 2018, 08:49:25 PM »
Holy Missing Person, Batman !!  Wow, Bruce - it's been FOREVER !!! What's going on?  Send me an email (I still have the same one I've had for 20 years).
Good to see you're still interested.
Regards,  Steve
