May 05, 2024, 01:34:11 AM *
Author Topic: What hath Goodwill wrought?  (Read 4476 times)
ka1tdq
« on: January 05, 2017, 10:22:54 PM »
2000 electrolytic capacitors for $10, new in the box. Just sayin'...
W6TOM
« Reply #1 on: January 06, 2017, 04:11:42 AM »
  Years ago I went to a Ham Swap and found two almost new tires the same size my pickup uses and for almost none thing, they sat in the loft in my garage for a few years before I needed them. You never know....
« Reply #2 on: January 08, 2017, 09:30:07 AM »
Hook em all up in parallel !   Grin
ka1tdq
« Reply #3 on: January 08, 2017, 09:32:46 AM »
...or series - parallel.  There's enough there to build a filter capacitor for a 3-500 amp!
Jon
« Reply #4 on: January 08, 2017, 09:58:04 AM »
Jon
A string of 200 in series gives you .5uf @ 3200v
Then use 10 strings of 200 each to give you 5 uf @ 3200v...
Then buy 9 more boxes from Goodwill, and do the same:
50uf @ 3200v!!
Wd5JKO
ka1tdq
« Reply #5 on: January 08, 2017, 12:17:53 PM »
Oh, can you imagine?!  I'd be scared to power that thing on. At least, more scared than I usually am the first time I power my stuff on.
Jon
« Reply #6 on: January 08, 2017, 05:54:59 PM »
I saw a guy at a ham-fest put 3-4 apparently very heavy and rather tatty looking 1 cubic FT boxes in the dumpster before leaving. Indeed they were heavy because they were full of all kinds of transformers and chokes from fist-size down to 2" cube size. The boxes split open when they hit the bottom of the empty dumpster and I had to get a helper so I could hand the transformers through the dumpster window to him. He had a cart and we filled it up, saved them all. Most have been used or given away by now.
« Reply #7 on: January 08, 2017, 08:20:59 PM »
Good price.  New, Quantity 2000   100uF 16V caps would cost around $80.00 !
ka1tdq
« Reply #8 on: January 08, 2017, 09:22:42 PM »
...and there were two other boxes there.  I just didn't need 6000 electrolytics.
Every project, I go to Fry's Electronics and pick up a couple.  They're about $2 a piece, so this should pay for itself  shortly.
I also picked up last weekend from Goodwill a 4' tall all steel enclosure that holds 19" shelves.  There's a door on front and back.  I don't know what to do with it yet, but it has to be the project of projects.  Sort of, the Holy Grail of ideas.
I can't think of anything yet... I still need to finish my other rig (the one with the 1920's RCA faceplate on it).
Jon
« Reply #9 on: January 08, 2017, 11:34:02 PM »
Jon
I have a basement full of this kind of stuff.  Cabinets, enclosures of all types just waiting for me to build something in them.  Interestingly I have built about 15 projects in some over the last few years.  Some of the cabinets have been hanging around for 30-40 years.
As far as the caps go,  I have thousands of them,  one size, 47ufd 25v qty 6000,  many other sizes (in large quantities) that i can't remember right now.  Everything from small silver micas to large electrolytics.
Capacitors, probably something north of 100,000 counting the small ones.  Resistors, everything from 1/8w to 300w, easily well over 200,000.  Ask me if I thing I'll ever use all of them.
Jon,  use caution collecting large quantities of parts or you'll end up like me,  hundreds of thousands of parts of all types and nowhere near enough time in life to ever use all of them.
Only good thing is I can probably build just about any project and not have to buy anything.  I also stopped going to hamfests decades ago.  If I think I'd like to go to one, I just walk around my basement.
