April 29, 2024, 02:15:38 AM *
Author Topic: Collins 310-B Cap Replacement ?  (Read 3312 times)
Carl WA1KPD
« on: September 29, 2016, 11:23:50 AM »
Hello all,
I have a Collins 310 B, the 15 watt exciter they built in the 50s. It works fine but I am planning on replacing the electrolytics and several wax caps and one of those purple black beauty type caps.
There are a number of light tan postage stamp type caps that I have never seen. Anyone know how well these hold up, or should I plan on replacing those.
« Reply #1 on: September 29, 2016, 03:44:19 PM »
A picture might help. Are you referring to the tan ones in the picture below?
Carl WA1KPD
« Reply #2 on: September 29, 2016, 04:11:17 PM »
Yes
« Reply #3 on: September 30, 2016, 02:52:19 PM »
Carl....I replaced  all the caps EXCEPT the tan postage stamps...My 310 B works well and is very stable...I have also modified it for 160  (easy) Good luck...
Carl WA1KPD
« Reply #4 on: September 30, 2016, 03:43:52 PM »
I'm pretty much there. The only ones I am not bothering with are the several bath tub caps that are part of the sidetone circuit. I don't see using that so am not concerned.
HUGE difference when I replaced the .02 that went from the power cord to ground. That baby was leaking.
Someone previously added a home brew brute force AC filter wound on two dowels and covered with the old cloth electrical tape. I think I am going to pull it while I am in there as I suspect it was put in for TVI purposes.
I understand 160 is a simple as changing the PA coil to a 160 one and running the bandswitch in the 80 meter position?
Thank for the help Steve!
