April 26, 2024, 02:52:21 PM *
Author Topic: Open Wire Feeds  (Read 3590 times)
« on: February 28, 2005, 01:20:07 PM »
In case you missed it and you have the itch to throw up some antennas in winter, here's a good article, that just won the 2004 ARRL, Bill Orr, W6SAI, Technical Writing Award:
Open Wire Feed Line - A Second Look
http://www.remote.arrl.org/tis/info/pdf/0404034.pdf
« Reply #1 on: February 28, 2005, 06:39:47 PM »
Good article.
HTML version here.
http://www.findarticles.com/p/articles/mi_qa3748/is_200404/ai_n9389476
You can run your own numbers here.
http://fermi.la.asu.edu/w9cf/tran/index.html
And you can also factor in losses in the tuner (something the article didn't do) here.
http://fermi.la.asu.edu/w9cf/tuner/tuner.html
Good info on the loss in the major types of commercially available ladders lines here (and some info on tuner loss too). From Wes Stewart, N7WS.
http://users.triconet.org/wesandlinda/ladder.htm
On the above page there is a link to an article on ladder lines by Wes. In the article he measures the loss of wet ladder line. It is MUCH higher. In the article and on the page he does point out that these numbers probably represent the worst possible scenario in actual use/practice. That said, they are something to consider, especially if you are going to have long runs and live in a wet location or one that get a lot of icing in the winter.
http://users.triconet.org/wesandlinda/ladder_line.pdf
