Title: Open Wire Feeds Post by: Pete, WA2CWA on February 28, 2005, 01:20:07 PM In case you missed it and you have the itch to throw up some antennas in winter, here's a good article, that just won the 2004 ARRL, Bill Orr, W6SAI, Technical Writing Award:
Open Wire Feed Line - A Second Look http://www.remote.arrl.org/tis/info/pdf/0404034.pdf Title: Open Wire Feeds Post by: Steve - WB3HUZ on February 28, 2005, 06:39:47 PM Good article. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
HTML version here. http://www.findarticles.com/p/articles/mi_qa3748/is_200404/ai_n9389476 You can run your own numbers here. http://fermi.la.asu.edu/w9cf/tran/index.html And you can also factor in losses in the tuner (something the article didn't do) here. http://fermi.la.asu.edu/w9cf/tuner/tuner.html Good info on the loss in the major types of commercially available ladders lines here (and some info on tuner loss too). From Wes Stewart, N7WS. http://users.triconet.org/wesandlinda/ladder.htm On the above page there is a link to an article on ladder lines by Wes. In the article he measures the loss of wet ladder line. It is MUCH higher. In the article and on the page he does point out that these numbers probably represent the worst possible scenario in actual use/practice. That said, they are something to consider, especially if you are going to have long runs and live in a wet location or one that get a lot of icing in the winter. http://users.triconet.org/wesandlinda/ladder_line.pdf |
