March 31, 2026, 06:23:18 AM *
Author Topic: 4KW 4000V DC POWER SUPPLY  (Read 2326 times)
wa2ujx
« on: June 14, 2015, 11:19:09 AM »
Built by Henry this commercial 240 VAC, choke input 4000 - 4800 VDC 1A power supply fits in bottom of rack on a 17-1/2 X 17-1/2 inch, 1/4 inch thick aluminum plate. Also has 1/2 voltage choke input filtered power for driver tube. Designed for a plasma generator using 3CX-3000A outputting continuous 2000 watts. Transformer alone weighs 78 lbs. and the supply is similar to the one used in the Henry 4K ultra amp. Tested and many pictures and info available on request. No sense in trying to gather components and build a supply when this one is designed right from the start. A great power source for a large HB amp/trans. Has soft-start circuit but needs the timing tube. Pick up only in Rhinebeck NY or will deliver within 25 miles. Asking $390.00. inquire to WA2UJX  Carl at carlandkaren67@gmail.com
Page created in 0.024 seconds with 17 queries.
