May 05, 2024, 04:29:23 PM *
Author Topic: Auto tune Viking 1...  (Read 2636 times)
N8ETQ
Mort
« on: April 24, 2015, 02:22:38 PM »
    I need a VFO for this thing anyway, Since he's
sitting right there next to an ART-13... Well, one
can see how my mind wandered.
    I didn't realize how close in size the Vik. and
the ART are. My cat will love the "Non-Split" level
floor plan this winter.
    I already searched this forum for "ART-13 PTO Output"
with and without ("), ART-13 PTO, and finally just ART-13.
No results on DUCK either.  Looking for an easy way to
pull excitation out of the ART-13.
  AM Phone: "If it ain't here, It ain't anywhere!"
/Dan
« Reply #1 on: April 24, 2015, 06:39:59 PM »
Answer "tongue in cheek"  Tongue
Hmmm, so I guess size and efficiency are not concerns. If you make a 100 watt rated 20 db attenuator, that takes 100 watts down to 1 watt. One watt at 50 ohms is about 7v rms or 10v peak. That will drive the Viking I VFO input. You will then have the only 813 driving a 6AU6.  Huh
Better yet power the ART-13 off dynomotors using a big 28V 50 amp power supply.
Good luck with your project.
« Reply #2 on: April 24, 2015, 09:32:33 PM »
If you are satisfied with output from the ART-13 oscillator or a low power stage following it, you can look into salvaging the RF amp section from an older solid state HF 'rice box' or a small 2-transistor class AB "CB linear amplifier". Only a few watts would be needed, so the attenuation could be done on the amp's input with a series resistor. The scheme would avoid having to hack and modifiy the ART-13's RF circuits excessively. It would be as possible to try coupling the signal from the last stage before the ART-13's 813, by use of a separate 2-4 turn coil at the cold end. No matter what, you are in for some experiments so please keep us posted if you go forward.
What is a 'non-spilt' level for the cat?
« Reply #3 on: April 26, 2015, 01:23:03 PM »
  I once saw an Arc-5 transmitter that was "chopped" such that it was only about 5" deep, yet still looked original from front or rear view. It was converted to be a dedicated VFO. This was at a swap fest, and when I went back after reconsidering it, the guy was gone. He was a machinist and really did a good job with all the mechanical details.
  Perhaps if you have a junker ART-13, you can take a similar approach with the goal to use just the VFO, and perhaps a buffer stage to use as a stand alone VFO, and power it from the Viking 1 Low B+. If the power needs are not compatible, make a combined plate and filament supply, much like Knight Kit did with their stand alone VFO. I don't know the layout of an ART-13, so the "saws-all" chop job might not be possible.
« Reply #4 on: April 26, 2015, 04:18:30 PM »
How about a Johnson 122?
http://amfone.net/Amforum/index.php?topic=38294.0
