December 18, 2025, 11:01:04 PM *
Author Topic: SX-28, Diving In  (Read 3174 times)
W7SOE
« on: April 20, 2015, 02:08:02 PM »
The SX-28 cleaned up ok.  Minor rust on the chassis, the underside looks very good.  I am following the example here to get at all the caps:
http://antiqueradio.org/halli12.htm
I manged to get the first RF section out, that is a bit of surgery!
Unfortunately, when I pulled out the bandswitch shaft, the center (turning) part of the front most bandswitch pushed out the turning bit of the wafer switch.  :-(
Nothing appears damaged, the contacts are just bent out of the way.  No idea how I am going to get that back in there........
Rich
« Reply #1 on: April 21, 2015, 09:35:14 AM »
can't see the damage in the image...
...some folks may have a parts chassis hanging about, depending on if you can repair it or not a replacement may be called for.
                       _-_-
W7SOE
« Reply #2 on: April 21, 2015, 12:08:47 PM »
Here is the wafer switch part that pushed out.  Maybe I can bend the contacts and get it back in.  Maybe not....
Rich
« Reply #3 on: April 21, 2015, 12:36:08 PM »
I suggest you look for a replacement part.  Bending those contacts can be a pita and puts undue stress on them.  They may be a problem from now on if you do that.
« Reply #4 on: April 21, 2015, 01:17:21 PM »
How are the fingers?
IF the fingers are still ok, then you can likely slide it back in... in some cases you may need to gently drill out a rivet
or two that holds the fingers first, remove the fingers, then replace them with either a rivet/eyelet (if you have one) or
small screws w/locking compound on the nuts. You can buy small hardware on the internet/ebay these days.
Those are likely #2 or #1 size screws... there are also metric sizes and British thread sizes too... for that exact fit!
There are also #0 size...
W7SOE
« Reply #5 on: April 21, 2015, 01:32:49 PM »
I like this solution!  I can order hardware while recapping.   Thanks
Rich
Page created in 0.135 seconds with 18 queries.
