Title: SX-28, Diving In Post by: W7SOE on April 20, 2015, 02:08:02 PM The SX-28 cleaned up ok. Minor rust on the chassis, the underside looks very good. I am following the example here to get at all the caps:
http://antiqueradio.org/halli12.htm I manged to get the first RF section out, that is a bit of surgery! Unfortunately, when I pulled out the bandswitch shaft, the center (turning) part of the front most bandswitch pushed out the turning bit of the wafer switch. :-( Nothing appears damaged, the contacts are just bent out of the way. No idea how I am going to get that back in there........ Rich Title: Re: SX-28, Diving In Post by: WBear2GCR on April 21, 2015, 09:35:14 AM can't see the damage in the image...
...some folks may have a parts chassis hanging about, depending on if you can repair it or not a replacement may be called for. _-_- Title: Re: SX-28, Diving In Post by: W7SOE on April 21, 2015, 12:08:47 PM Here is the wafer switch part that pushed out. Maybe I can bend the contacts and get it back in. Maybe not....
Rich Title: Re: SX-28, Diving In Post by: Jim, W5JO on April 21, 2015, 12:36:08 PM I suggest you look for a replacement part. Bending those contacts can be a pita and puts undue stress on them. They may be a problem from now on if you do that.
Title: Re: SX-28, Diving In Post by: WBear2GCR on April 21, 2015, 01:17:21 PM How are the fingers?
IF the fingers are still ok, then you can likely slide it back in... in some cases you may need to gently drill out a rivet or two that holds the fingers first, remove the fingers, then replace them with either a rivet/eyelet (if you have one) or small screws w/locking compound on the nuts. You can buy small hardware on the internet/ebay these days. Those are likely #2 or #1 size screws... there are also metric sizes and British thread sizes too... for that exact fit! There are also #0 size... _-_-bear Title: Re: SX-28, Diving In Post by: W7SOE on April 21, 2015, 01:32:49 PM How are the fingers? IF the fingers are still ok, then you can likely slide it back in... in some cases you may need to gently drill out a rivet or two that holds the fingers first, remove the fingers, then replace them with either a rivet/eyelet (if you have one) or small screws w/locking compound on the nuts. You can buy small hardware on the internet/ebay these days. Those are likely #2 or #1 size screws... there are also metric sizes and British thread sizes too... for that exact fit! _-_-bear I like this solution! I can order hardware while recapping. Thanks Rich |
