April 28, 2024, 09:43:51 AM *
Author Topic: ebay transformers of interest  (Read 2370 times)
« on: March 30, 2015, 12:03:36 PM »
Since I looked at them and separated the wheat from chaff..     not mine.  filtered out for interesting (mostly plate) XFMR only:
5900/4730VCT@300mA (ICAS:425mA). Pri:115/230V, 900VA. 'CHT Multi Volt' T-15P19
http://www.ebay.com/itm/221723442189
1455VCT@250mA. Pri:115V.
http://www.ebay.com/itm/361082536144
2250VCT 565mA with twin 120V pri., (two available)
http://www.ebay.com/itm//111618288065
560VCT@0.14A, 6.3VCT@6.5A with 115V Pri., WE model 360Y, includes two selenium rectifiers..
http://www.ebay.com/itm/131467904978
UTC NO. E-4512B NL-69778-1 30,000 OHM W5c Plate Coupling Transformer NOS
(I do not know what this is really for.) --opcom
http://www.ebay.com/itm/381204955193
1250VCT@0.5 amp, Pri 210-220-230-240V
http://www.ebay.com/itm/281257312429
1420VCT@250MA, with 105-115-120V pri.
http://www.ebay.com/itm/251881921564
920VCT@90mA and 1240VCT@75mA (two secondaries).  pri: 103/115/126V 50-1000Hz
http://www.ebay.com/itm/361243778925
365VAC@0.5A with tap at 335V, pri:105/115/120/125V
http://www.ebay.com/itm/301575235436
3500/3000/2400VCT@500mA, pri:105/115/220/230V 50/60Hz UTC CG-308
http://www.ebay.com/itm/351315580781
Peter Dahl unit from Henry 2K amp
http://www.ebay.com/itm/301575392107
3750/3000VCT@300mA, THORDARSON T-19P60
http://www.ebay.com/itm/381041359036
1450VCT rated 125VA, Pri:110V. THORDARSON T-6280 (T-62P80?)
http://www.ebay.com/itm/321202990875
6KV/3.5KVCT@720mA, 2800VA, volts selected by PRI tap., Pri 110V, Thordarson T-47373
http://www.ebay.com/itm/331304316218
plate unit for Henry 3K Classic X MKII
http://www.ebay.com/itm/161651455345
1200VCT@310mA. With 'bias tap'225V@0.04A. Pri 120V 195VA.
http://www.ebay.com/itm/111631344348
800VCT@110mA, 5V@2A, 6.3VCT@3A. pri 100-130V SOLA 7106
http://www.ebay.com/itm/131102044712
1250VCT: 950VDC@200mA/900VDC@500mA. "1250VCT no load". twin 115V pri.
http://www.ebay.com/itm/171714772182
1235VCT@500mA, 5V@6A. pri 115V
http://www.ebay.com/itm/371197858818
plate for AM-6545A/GRC-193A. 27.5V inverter to 1600VDC
http://www.ebay.com/itm/311328395014
1130VCT@150mA, 1190VCT@0.025A, 412VAC@500mA with tap 349V. Pri 105/115/125.
http://www.ebay.com/itm/161491087243
465VCT@0.05A, 6.3V@9A, 5V@2A. Pri 105/115/125
http://www.ebay.com/itm/280991901900
750VCT@100mA, 5V@2A. Pri 110/115/125
http://www.ebay.com/itm/220793611802
2000/1500VCT@300mA. Pri 115V. UTC S-46
http://www.ebay.com/itm/291393939828
820VCT@100mA. 6.3v@2.5a 6.3v@1.2a 5v@2a.
http://www.ebay.com/itm/221389315905
1000/930/865VAC@300mA. Pri: 115/120V "with 4H@300mA choke"
http://www.ebay.com/itm/201318904280
1800VCT@400mA  Chicago 138852
http://www.ebay.com/itm/301568509978
650VCT@230Ma, pri 115
http://www.ebay.com/itm//291067877080
760VCT@220mA, 5V@3A, three 6.3V@7, 5, and 1.2A.  Stancor P-8169
audio tube to line output +24dBm 20KCT/5K 5mADC to 600CT/150 Ohm
http://www.ebay.com/itm/111216774484
audio UTC CG-132 'Triode Plate to P.P. Grids'
http://www.ebay.com/itm/271512424736
audio plate to grid 15K to 60K (no DC), +8dBm, 30Hz-20KHz  TRW-UTC O-4
http://www.ebay.com/itm/361255380213
