Title: ebay transformers of interest Post by: Opcom on March 30, 2015, 12:03:36 PM Since I looked at them and separated the wheat from chaff.. not mine. filtered out for interesting (mostly plate) XFMR only: AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
5900/4730VCT@300mA (ICAS:425mA). Pri:115/230V, 900VA. 'CHT Multi Volt' T-15P19 http://www.ebay.com/itm/221723442189 1455VCT@250mA. Pri:115V. http://www.ebay.com/itm/361082536144 2250VCT 565mA with twin 120V pri., (two available) http://www.ebay.com/itm//111618288065 560VCT@0.14A, 6.3VCT@6.5A with 115V Pri., WE model 360Y, includes two selenium rectifiers.. http://www.ebay.com/itm/131467904978 UTC NO. E-4512B NL-69778-1 30,000 OHM W5c Plate Coupling Transformer NOS (I do not know what this is really for.) --opcom http://www.ebay.com/itm/381204955193 1250VCT@0.5 amp, Pri 210-220-230-240V http://www.ebay.com/itm/281257312429 1420VCT@250MA, with 105-115-120V pri. http://www.ebay.com/itm/251881921564 920VCT@90mA and 1240VCT@75mA (two secondaries). pri: 103/115/126V 50-1000Hz http://www.ebay.com/itm/361243778925 365VAC@0.5A with tap at 335V, pri:105/115/120/125V http://www.ebay.com/itm/301575235436 3500/3000/2400VCT@500mA, pri:105/115/220/230V 50/60Hz UTC CG-308 http://www.ebay.com/itm/351315580781 Peter Dahl unit from Henry 2K amp http://www.ebay.com/itm/301575392107 3750/3000VCT@300mA, THORDARSON T-19P60 http://www.ebay.com/itm/381041359036 1450VCT rated 125VA, Pri:110V. THORDARSON T-6280 (T-62P80?) http://www.ebay.com/itm/321202990875 6KV/3.5KVCT@720mA, 2800VA, volts selected by PRI tap., Pri 110V, Thordarson T-47373 http://www.ebay.com/itm/331304316218 plate unit for Henry 3K Classic X MKII http://www.ebay.com/itm/161651455345 1200VCT@310mA. With 'bias tap'225V@0.04A. Pri 120V 195VA. http://www.ebay.com/itm/111631344348 800VCT@110mA, 5V@2A, 6.3VCT@3A. pri 100-130V SOLA 7106 http://www.ebay.com/itm/131102044712 1250VCT: 950VDC@200mA/900VDC@500mA. "1250VCT no load". twin 115V pri. http://www.ebay.com/itm/171714772182 1235VCT@500mA, 5V@6A. pri 115V http://www.ebay.com/itm/371197858818 plate for AM-6545A/GRC-193A. 27.5V inverter to 1600VDC http://www.ebay.com/itm/311328395014 1130VCT@150mA, 1190VCT@0.025A, 412VAC@500mA with tap 349V. Pri 105/115/125. http://www.ebay.com/itm/161491087243 465VCT@0.05A, 6.3V@9A, 5V@2A. Pri 105/115/125 http://www.ebay.com/itm/280991901900 750VCT@100mA, 5V@2A. Pri 110/115/125 http://www.ebay.com/itm/220793611802 2000/1500VCT@300mA. Pri 115V. UTC S-46 http://www.ebay.com/itm/291393939828 820VCT@100mA. 6.3v@2.5a 6.3v@1.2a 5v@2a. http://www.ebay.com/itm/221389315905 1000/930/865VAC@300mA. Pri: 115/120V "with 4H@300mA choke" http://www.ebay.com/itm/201318904280 1800VCT@400mA Chicago 138852 http://www.ebay.com/itm/301568509978 650VCT@230Ma, pri 115 http://www.ebay.com/itm//291067877080 760VCT@220mA, 5V@3A, three 6.3V@7, 5, and 1.2A. Stancor P-8169 audio tube to line output +24dBm 20KCT/5K 5mADC to 600CT/150 Ohm http://www.ebay.com/itm/111216774484 audio UTC CG-132 'Triode Plate to P.P. Grids' http://www.ebay.com/itm/271512424736 audio plate to grid 15K to 60K (no DC), +8dBm, 30Hz-20KHz TRW-UTC O-4 http://www.ebay.com/itm/361255380213 |
