May 03, 2024, 03:07:19 PM *
Author Topic: Experimental Licensee to Operate Betqween 2.5 and 16 MHz  (Read 13555 times)
« on: February 15, 2015, 02:23:48 AM »
From the ARRL web site dated 2/13/15:
"The ARRL has asked a Massachusetts company that plans to conduct experimental transmissions over wide portions of the HF spectrum either to avoid Amateur Radio allocations or to announce the times and frequencies of their transmissions in advance. The FCC last fall granted MITRE Corporation of Bedford, Massachusetts, a 2-year Part 5 Experimental License, WH2XCI, to operate 21 transmitters at 10 fixed New York and Massachusetts sites. MITRE plans to test wideband HF communication techniques on a variety of bands between 2.5 MHz and 16 MHz...."
For the rest of the story, go here: http://www.arrl.org/news/arrl-warns-experimental-licensee-to-avoid-interference-to-hf-ham-activity
If you hear weird stuff on the bands which sounds different from the normal weird stuff we hear, it might be this stuff.
KX5JT
John-O-Phonic
« Reply #1 on: February 15, 2015, 04:53:21 AM »
I saw this earlier.  What is going on here?  What are they doing?  WHY is the FCC allowing them to do this?? AHHHH!!!!!!  I feel so marginal now.
AMI#1684
WB3JOK
« Reply #2 on: February 15, 2015, 10:07:08 AM »
Hope the ARRL can at least get them off the ham bands... remember that BPL crap a few years back? That seems to have gone away. Good thing, too.
W1FVB
VB Radio
« Reply #3 on: February 16, 2015, 09:30:07 AM »
George Carlin would have been proud  Smiley
vbradio.wordpress.com
« Reply #4 on: February 16, 2015, 10:18:32 AM »
http://www.tvtechnology.com/article/list-of-experimental-licenses-reveals-interesting-hf-data-comm-experiments/274152
W4EWH
« Reply #5 on: February 16, 2015, 12:44:07 PM »
MITRE is looking to take over the HF bands that aren't in demand for shortwave broadcasting, Maritime services, Fixed services, and (probably) Ham Radio. We're sitting on the only pieces of RF spectrum that the FCC hasn't been able to auction off for billions of dollars, and Uncle Sam wants to know if he can get money for the low bands.
W1AC
« Reply #6 on: February 16, 2015, 08:48:39 PM »
These are mind control transmitters. You are all part of the conspiracy.
« Reply #7 on: February 16, 2015, 10:53:39 PM »
Yes. Now you know why I always bring up unusual applications and perform odd experiments. There are many others just like me...
All that PMing and FMing and the little diode notches in the keep-alive corners - it is all part of the plan and contains encoded subliminal neuro-aural downloads. CODE NAME BAND PLAN! Catchy name, eh?
We are legion! We bite the arm! Global Dominion! I tell you only because it is too late! MUUUUuuuhahahahahaaaa.
KX5JT
John-O-Phonic
« Reply #8 on: February 17, 2015, 01:35:21 AM »
I've been seeing strange stuff on the bands.  I want to blame this Mitre license because I know they are out there but maybe it's not related.  Does anyone know what is going on here on the upper part of the 75 meter band?  Huge swaths being wiped out by rushing digital sounds...
AMI#1684
« Reply #9 on: February 17, 2015, 03:30:57 AM »
It's only 10 KHz wide. Could be International DRM station (although I think they might be wider), could be SSTV, could be some amateur digital voice stuff, or it could be a Class E station tuning up  Cheesy
KX5JT
John-O-Phonic
« Reply #10 on: February 17, 2015, 04:16:09 AM »
Ah, maybe the DRM because it was consistent for more than 20 mintues while I was monitoring 3.878  -- it never unkeyed.
AMI#1684
WB3JOK
« Reply #11 on: February 17, 2015, 04:36:00 PM »
Patrick, your cat is using your laptop again...  Grin
Tom W2ILA
« Reply #12 on: February 20, 2015, 08:48:42 PM »
It's the Boston buzzy.  Conditions to Boston must be good today.
« Reply #13 on: February 21, 2015, 08:27:43 AM »
Send a check to ARRL and it will stop.
WB3JOK
« Reply #14 on: February 21, 2015, 10:54:15 PM »
I heard something similar wiping out the top end of 40 meters the other night... figured it was government jamming of a broadcaster (there's a Christian station around 7300).
Page created in 0.075 seconds with 19 queries.
